Got Ow3ed something hardcore by a Blue S15 trial body kit, 19's and one nicely worked engine, running 16psi apparently but had external wastegate so not running stock turbos very nice indeed, and great guys too.
Just quickly-you wouldn't happen to own a white R34 GT-T like your avatar photo,wouldya? Coz I spotted a neat car as per described,and parked next to it,at the Shell servo' in Fyshwick this afternoon...and there was a gunmetal grey R33 GTS(T?) parked the other side of the servo,too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1176949
I spotted that Blue S15 once, does it have chrome windscreen wipers or something? Only thing i can fault it for :rant:. he was having a squirt against some guy in a REX in tuggers from the lights to the form one lane infront of the shops. He won, car sounded wicked too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1177875
saw a burgandy r33 in dickson had like black/carbon fibre inserts were the rear lights are you know like that triangle thing :rant: it had gtr badges though i dont think it was. had gtr front bar not sure of the side skirts and had a super dupper rear wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178717
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. terminal, that yours??
also, a stock-looking black 33 with an obscenely loud and horrible sounding exh. drive past subway in fishies. if thats anyone here, please change it. it sounded like a carby lancer with a cannon!!! *cringe*
d
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178736
you had me worried it was me ;) but i havent been to fyswick in ages so i am safe :D
also would have to agree funniest miss spelt word ever ;):)
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179505
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. d
Yepp, that was my beast :)
Unichip didn't go in cause they were having problems locating the wire for the TPS. This is sort of a blessing, cause I was playing with the TPS and trying to find the wire on the ECU for it. Found the wire and I also found out why I get a slight flat spot when it's cold... The TPS needed adjusting, now it's all good and not giving false readings when cold (that's why that couldn't find the output) I'll go back out there tomorrow and tell them.
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179734
Yet?
Joining me and jay in the unichip fraternity at some stage?
LOL - yepp, soon I hope !! Just had a slight delay with getting it in. APS said that I'm the first to put a Unichip and the boost control module into a Stagea, so we've had to make up our own wiring diagram etc...
I 'think' it's all good to go now.... hopfully....
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179737
Soptted a R33 with Gold rims today at the chisholm round about. was in the back seat of a lancer.... gave you some looks... saw a lil smile..
Also a Maroon R33 with GTR badge in the front grill, coming out of Qbn tonight..
Was also in the lancer...
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1180328
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
