sounds alot like andrew with his new buddy club p1's :P
Nah wasnt me, Ive heard of that car before, scared the shit out of me when my mate saw it on the back of a truck and asked what was wrong with my car when it was sposed to be elsewhere
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1188288
ok today ive spotted a black r32 (nice turbo), a maroon R33 and the blue s15 with chrome windscreen wipers going past capital funland/gus' cafe. also spotted a black R33 going along athlon dr. and a white gts25t parking at the front of woden plaza (near woolworths) looked like 2 ladys driving but i dont want to offend anyone :D
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1188465
Spotted yesterday: Me sitting in the passenger's seat of Nugget's GTR.
I thought the GTS-T I once drove moved quick but Holy moly GTR's move FAST!
:thankyou: and that,ladies and gentlemen,is yet another reason to own a GTR...
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1188843
come on i was taking it easy we never got out of third :)
that was only straight line power if my steering wasnt out and needed a wheel alignment i would have shown you cornering speed :burnout:
GT-R's exept no substitutes!
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1188991
Spotted a silver R33 GTR with white wheels sitting in philip accross the road from brian hall. very nice
yeah MIVEC ill take you for another drive when it gets out of the shop. hey you should buy one and kerb can buy the fto off you then he can sell the wrx
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1189622
I spotted a red nissan Mira or Micra whatever that small car is. anywho, it had a massive nismo sticker on it a nd was trying (failing) to drag a lancer.... a sad day for all
lol! also spotted this vehicle in civic circling it almost all day yesterday... it was funny!
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1189648
i didn't know i owned a cafe :aroused:
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1189932
Spotted a white 33, bout to get a re-spray on the front bar by the looks of it (all stripped) at about 4:30 near maccas.
A black GT-R very tidy driving across the bridge at qbn bout 5 very tidy :D, also today a maroon 32 gts-t very tidy, wing drove past it outside city link plaza..
aaaaannnnnddd... on da 30th around the corner from UPS in fyshwick a silver 33 chrome mags tidy, wing, tinted windows.. bout all i could see very nice tho!
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1190028
also spotted p1later at maccas in quenbeyan around 3ish. nice ride bro said hi and spoke a few mins nice lad he is.
Cheers! Saw you rolling up the driveway and recognised that huge FMIC. Car sounds tough! Thanks for the chat to, nice to finally talk to someone off the forums in person.
Could have been me going to work.
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1190141
Spotted a White S2 R33 turning onto haydon drv from ginninderra drv this arvo, and also spotted a Silver S2 R33 turning onto northbourne from antill st tonight. both times i was in my cruiser though.
Also, followed a silver R32 with a funky bonet scoop out of fyshwick which turned onto canberra ave heading towards struggle town.
Oh, and another one, i spotted on Monday a Wine R33 with a massive blitz front mount and a few patches of miscoloured paint outside BDL fyshwick when i walked out.
https://www.sau.com.au/forums/topic/30059-spotted/page/122/#findComment-1190508
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
