Where abouts on the South Coast are you from, paul? I used to live near Nowra/Jervis Bay.
No decent spotted today..  well, I saw a maloo at hawker yesterday. Not being a holden fan at all it still seemed pretty fancy looking for a ute. I dont get the rear wings though.
Im actually from the far south coast between Narooma and Bega - not too many lines down this way :rolleyes:
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1219126
spotted a black series1 R33 on Athlon Dr around the back of the hyperdome about 4pm today.
also one of those really low hilux ute things (grey), at Woden, looked pretty cool :rolleyes: it seemed to be followed by some guys in an old 70's corolla who got it a little sideways in the wet lol
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1219166
where abouts in woden I was driving through last night about 730 may have been me
its hard to explain... you know the old carpark across from the bus interchange? it was the road that connects the interchange to the main road that everyone loves to cruise past the cafes, which is right next to the old carpark (im not sure if its called bonner court carpark or some sh!t..... bonner hehe) but yeh it wasnt around 7.30 it was around 4-4.30
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1219338
Spotted the other day in my street, a Maroon Series I Skyline with mismatching panels being followed by that really low orange Toyota Hilux (Low Intentions Club) that was at the Tsunami Cruise. Directly behind them was a police motorbike. Hope they hadn't done anything wrong cause it looked like he was trying to catch up to them.
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1219360
spotted a black R33 going towards gordon just before 4:30 i thought it was Leech, it looked pretty stock and had black on white plates, then i thought it was pirater but you dont have black on white plates in your avatar.
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1220593
spotted a black R33 going towards gordon just before 4:30 i thought it was Leech... then i thought it was pirater but you dont have black on white plates in your avatar.
Wasn't me, i was still at work. And yeah, only the dodgy standard plates :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1220809
Also a nice R33 GTR i think... Silver,bodykit, front mount... drive up my street..
Think its the one you were talking bout MIVEC.
That the one??
It's a hella nice car........the owner has no idea about it though...she bought it merely cos it's a Skyline.
I had to pop the bonnet for her!!
And to say it's low is an understatement!
https://www.sau.com.au/forums/topic/30059-spotted/page/135/#findComment-1220850
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
