Yeah that car has been there the last few days while i've been going in to see how my skirts are doing. my car feels naked driving around with no skirts
Let us know when you get your skirts on so we can all have a peek!
https://www.sau.com.au/forums/topic/30059-spotted/page/160/#findComment-1321993
spotted: a tosser in an silver v8 falcon...he came hammering up next to me and then sat next to me - if i backed off he did too, and if i sped up a bit he did the same, but he was swerving over pretty close to me in my lane which scared me cos he seemed really aggressive not just someone wanting to 'play'..
it was 1am and i was a bit freaked out...but finally he went away..
then, i get to the end of Athlon and was about to turn onto Drakeford (my arrow had just gone green) when a blue r31 ran the red... thank god i'd waited a sec before taking off!!
https://www.sau.com.au/forums/topic/30059-spotted/page/160/#findComment-1322996
Damn... V8 drivers... and 31 drivers..
Also spotted SPOOFN yesterday as he was pulling out of a side street and nearly hit the side of me. patience mate... patience.
I guess you could say he almost spoofd on you? :)
Ahh ok thats it *quits with the lame jokes*
https://www.sau.com.au/forums/topic/30059-spotted/page/160/#findComment-1323615
I don't know why it is, but whenever i'm not in my stagea i see skylines everywhere. spotted a white R33 turning onto haydon drv, then a maroon one with a massive wing go past me on belco way, then a gunmetal R32 (GTR?) in woden outside hogsbreath, then i saw Andrew (SkyGTRline) in woden driving straight past me.... lousy landcruiser not sticking out at all.
https://www.sau.com.au/forums/topic/30059-spotted/page/160/#findComment-1325860
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
