spotted a veeerrryy nice Midnight purple R33 GTR Vspec2 today on streeton drive, it caught up behind me then as we turned at the lights he pulled next to me and gave me a wave (i know him from somewhere i think he lives accross the road) anyway, i had to turn so i couldn't play, so he flawed it past me and took off like a bat out of hell (must have some serious work done) or as Jayce would say "some serious get up and boogie!" twas very hot! nice plates too!- VSPEC 2
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1492767
nice spot, but they dont exist
spotted Jayce and Erica at Pheasants nest servo on the way out of sydney, they were at a subie cruise, i was cruising with a hot rod, pure sex that car
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1493959
spotted a white R33 parked next to me in the Canberra Centre carpark on Sunday when I came back to my car...nice looking car...had a nice body kit and red snap on seat covers, that's all I can remember..
oh and a 180 and WRX making loud psssst noises thru every level of the carpark until they got to the level I was on, and then they parked nearby :lol:
also saw another white R33 on my way home (just before Parliament House)....gave a wave, got a REALLY weird look back like he couldn't work out why I was waving...hmmm or maybe the sun was blinding him...i dunno...but I'm sick of waving and just getting strange looks!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1496062
Saw a white series 1 33 in Weetangera with some nasty looking damage on the front and down the side... It occurs to me I don't really see many lines anymore :( I used to see bloody skylines all the time when I was driving around in my super awesome 626 XD
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1498556
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
