Spotted John's R31 going under the bridge leaving Queanbo' on Monday arv'. Looks VERY different to the last time I saw it,J! Spotted Andrew the NEW owner of Andrew's Veilside 33 at trivia last night;good to finally meet you!
I agree - was good to finally meet some of the guys off here. :P
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1770985
Hey white R33 S2 with nice bodykit and plates "SKY33T" you passed a stock-ish silver R33 S2 on your right, heading under commonwealth bridge towards Fyshwick.. that was me! Driving slowish cos I was on my way out to Ed's for a much needed broken part! (throttle sensor)
Anyway, G'day.
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1771313
now now kids! play nice.
spotted black r33 gtst. tv's in headrests. sounded much more tough than any sub 2.6l engine has any right to (teehee) and looked pretty noice. manuka around 9pm ish near tryst.
d
hey man, sure it was a gtst? sounds alot like mine and i was there at that time... and mine has the gtst on the rear boot at the moment:) i saw your beast in manuka too... the reason for the badge (yeah i know its rice) is i needed a new boot, and its yet to get painted, even though the paint is the exact same:)
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1772309
spotted ib6ub9 going through civic this arvo, about 3ish.....
also seen a silver R33 s2 with an sau sticker on the back window and a poorly kept R33 GTR (was a dissapointing example...) both at inline this moring....
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1772939
Spotted Jayce trying to steal bits from certain GTRs on Sunday arvo. Little bugger was trying it on in front of the entire AutoSalon 2! I told him off...
Bugger! Sprung! It's so hard to make off with 430KW's of RB goodness without Paul & Stace' noticing...LOL!
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1773976
Gunmetal R32 GTR with white TE37s parked up about 0930, not saying where in case it goes there a lot.
White R34 GTR heading along Commonwealth Ave
haha. that'd be mick, the guy who a) imported my car and B) has imported many many many other cars under the now defunct 15 year rule. good bloke. and i pleaded with him for his wheels, but no such luck :rolleyes:
i'd love to know which establishment he was parked at! :)
d
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1775977
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
