Saw a nice white 33 in Banks a little while ago. Had the decals down the doors and some interesting looking dark wheels with iodised red stripe?
Think i spotted that in Qbn. Series 2, white, shopping list on the doors and red detailing on the rims. Looked quite nice. Reminded me of a car that was featured in HPi once, had been worked on by Trojan. Might have even been the same car who knows.
https://www.sau.com.au/forums/topic/30059-spotted/page/312/#findComment-2308983
:D
Had to drop by the city watch house and the daily shitter did a head sometime this morning.
I missed seeing your Stagea tho. I luv em.
oh, no i wasn't in my car, i was on the 7th storey of my building we're building :P
https://www.sau.com.au/forums/topic/30059-spotted/page/312/#findComment-2313581
Spotted a white 32gtr pretty sure it was nicks, R34 wheels on the back of eurotow towing heading northbound on the federal highway late yesterday afternoon :yes:
Also spotted just after 2:00am the same eurotow truck returning back to Canberra with Rh9 and Jun on the back anything you would like to share with us Nick :dry:
https://www.sau.com.au/forums/topic/30059-spotted/page/312/#findComment-2323495
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
