Hey guys, havent been on for a while! I also havent seen many lines lately, Where are u all? Or am i working a whole lot more hence the reason for me being a "woden whore"! LOL Remember guys give a wave get a wave.... LOL see yas
Unlike your skyline witch I see all the time. You should move your car around the car park, like to different flaws and different arias around the car park. Other wise people see your ride in the same aria all the time they know where it will be if they decided to break into it. Just like they did with mine :)
Any ways that’s a sweet ride you’ve got there.
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2331503
I saw the mother of all ACT rego'd GT-R, R34 Gtr, green to purple hue, number plates "RH9" Has got some guts to have that as a number plate, but by the sounds of it (and what I read in Autosalon Magazine, close to 600 AWKW on low boost!!!!!!) It should be able to back it up. Any way spotted in front of Hoyts in woden along the "woden laps strip"
I believe it was 690awkw on 25ish-psi... or around that figure somewhere :banana:
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2333042
the guy who owns diablo (the crazy wrx) said on canberra cruises that he pulled 645ish kw's at autosalon
Yeah it was something insane like that. my mate knows one of the blokes who works on the car and he was told it was a new record for most powerful rex
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2334550
saw sinista's ride for the first time the other day going passed the southo. man that thing looks nice! i was feeling super cool in the bashed up falcon with mum in the passenger seat and groceries in the back.
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2336054
I think it was without nos but im not completely sure.
The other at denman cellars in gungahlin saw a crazy wide body celsior(i think). looked phat as.
Yesterday as i was leaving work for lunch saw a black 33. gave a wave got a wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2339589
not sure if you misread it (i didn't make it clear lol) but diablo said RH9 had that many kw's
diablo is on this moinths autosalon i think, some crazy ass kw's, stated as worlds most powerful rex.
both cars = :angry: haha
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2340343
he said this was a nos job, and he had three different settings wqith the lowest (for street) being 280ish, then 320ish then this
his new motor makes sumthin like 500-600- i think ima check out autosalon tomoz
EDIT: jsut checked the website and it says he made 513kw's at brisbane autosalon!
Edited by Gus-
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2342331
Hi chintami,
so is that ur car i spot everyday in woden????
hmmm must come and say hello.....
https://www.sau.com.au/forums/topic/30059-spotted/page/314/#findComment-2345389
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
