Taxi drivers hey. Driving down Northbourne last night a copper pulled up beside me, gave me a very weird look, then proceded to CUT ME OFF!.... he then sped off, merged into a turning lane without indicating, then pull out of it and kept going straight. I should have gotten his licence plate number and reported him, but I was too busy swearing at him.
Spotted a nice Blue R33 GTST in civic and a Maroon one in Dickson, but it had ugly chrome wheels.
It must be the latest thing to do, Good Friday I was driving along Athllon Dr and a Cop nearly ran me off the road. I swear he took the clear coat off my front bar :D
Automatically went to blast him with the horn...figured i would same time and possibly money by letting it go.
(I think this shouldve gone in What ticks you off thread...cos thats what grinds my gears)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3054931
Thats awesome Simmo.
Got an ETA on its return?
thanks man, not sure when itll be back yet, hopefully not too long i hope :whistling: . just steering it onto the back of the truck and having it move again has made me more impatient though heh.
spent quite a wwhile drooling over [YES-32R] at trojan, also spotted MKDR33 but ive been beaten to the spotted thread again hehe, good to meet you too man ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3055620
white four door r33 near civic yesterday.
also a black r33 with silver stripey tattoo bits in woden. i'd advise against parking next to the trolley return bays in that underground carpark - the trolleys don't have brakes, and the chaps collecting them don't care what stops them!
Edited by sigsputnik
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3062590
nice town you got here...
spotted a burgandy R33 last night at about 11ish on commonwealth av. I was in my dad's black ceffie.
passing thru canberra from syd. decided to stay a few days in Kingston.
so where you all at? there's so few imports here... and everyone drives riced up celica's??? wtf.
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063324
You must not be looking to hard... i reckon i see more imports in Canberra than when i am getting around Sydney and Melbourne. A lot of the skylines are further out south. Northside well except for passing through to get out of Canberra there is no need to go there :P
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063618
Spotted wingless silver R33 on Parks way 8.50 lastnight followed you from black mountain to Kings av bridge.
Aaahhhh that was you up my bum :) I'm ashamed to say but I actually thought your car was an old porsche, looking through my rearview mirror :( I'll be sure to wave next time I see ya
Also spotted R34-GTT last night on Hindmarsh Drive. Hey Mladz, did you go to the movies? saw you pull out of the carpark behind me at hoyts
Edited by R33Driftr
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063925
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
