Yea they made them in the R33 there called a '400R' they didnt make too many of them.
Um, no. This is a gen-you-whine 400R (one of only a few 33's I would own!):
Gorgeous, and VERY limited supply!
The only four door GT-R spec' cars were made under licence by Autech, as someone earlier pointed out. Specific, Autech only, parts(such as the rear quarters) single these cars out. Absoultely freaking gorgeous, IMHO. I would LOVE an Autech 33 four door; one of the best 'sleepers' I could want(OK, an RS6 is up there, too). Autech have turned out many, MANY uprated versions of other Nissans, but the 260RS and the four door series are easily my faves.
Do a Google image search for 'Autech' and be suprised...
Here's an Autech R33 sedan, such as Shell had pictured earlier:
And their R34 version(decidedly sexy, yes?)
https://www.sau.com.au/forums/topic/30059-spotted/page/495/#findComment-4050162
dropped into trojan to get strut brace,
johns white stagea (man i should have got one of these so i could put the hang glider on the roof
angelos white 33
2 s2 silver 33's
a charcole 33 and black r32 gtr,
man i really love seeing so many so close to each other
peace
https://www.sau.com.au/forums/topic/30059-spotted/page/495/#findComment-4050227
there was a black 32 gtr on monday when i went in there, angelo told me to sit in it (looking for options to give myself more head room when i have a helmet on).
speaking of black 32 gtrs, i saw one at ABS molonglo today at about 1pm, had 33 gtr wheels on it... yummy! and also a moroon 32 gtst on parkeway heading towards civic from glenlock this arvo at about 5:25pm
https://www.sau.com.au/forums/topic/30059-spotted/page/495/#findComment-4051021
Spotted a blue R32 (might have been a GTR) on the back of a trailer turning into Torrens, was being pulled by a silver Commodore ute.
Also a gunmetal R32 GTR at the intersection at John McGrath Woden, turning towards Weston.
Both about 4pm or so...
https://www.sau.com.au/forums/topic/30059-spotted/page/495/#findComment-4051056
Mine was there
angelos white 33
2 s2 silver 33's
peace
https://www.sau.com.au/forums/topic/30059-spotted/page/495/#findComment-4051948
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
