saw gtrkat and her hubby in their audi at the lights of ginnenderra and GDE we waived and they waived back.. also saw frink and blueprint at the lights on hindmarsh and tugger pkwy i didnt realise it was them until we were around the corner. i was in ZCR's car but seeings as he hadnt posted yet i thought i would..
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4255604
Haha, thank god for that then....
John just rang to tell me that I've lost 30kw's somewhere though :-(
dang.. he rang me this morning to tell me that i have severe wiring problems and that my rear muffler is fked.. looks like a fun day for john at torjan giving everyone bad news.. at least its getting fixed *fingers crossed*
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256280
Just got off the phone with John again... Turns out that my middle muffler is rooted and my rear muffler is probably gone as well. Would explain the random detonation that was happening.... Off to PowerTone in Fyshy for another legal cat back system.
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256324
me and bluprint spotted zane in woden last night around 7pm ish....
ya'll beat me to it! but yes, there was some spottage last night!
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256679
Yes I spotted a certain someone showing off!!!! ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256998
spotted a dark blue 32 or 33.. looked more like a 32 but you never know (it was far away and the dark colour hides the body contours.. thats my excuse)
it drove past my window in immigration belconnen about 3 minutes ago. it had rather large rims.. 18's or 19's
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258330
Spotted a White R33 heading along Hindmarsh towards Fyshwick at lunch time. Also a White R33 with a large bodykit on it in Fyshwick on my way to Harris Tech.
(Car's booked in tomoz to get my two new mufflers sorted, yay, hope it will be quiet enough for the police but loud enough for me)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258409
did you see my car when you were out at trojan? im hoping that she is ok
looks as thought i may need a new exhaust as well.. might just put my pea shooter back in until i can afford it
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258642
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
