I can't believe you're posting on SAU only a few days after the new WoW thing came out. :(
I know!
Got Level 75 on Sunday afternoon though :banana:
To be honest, i came back cause i blew my Turbo on Thursday and was poking around to see what was what
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4266209
gungrey wingless r32 just drove past my window at work (ie up joynton smith drive past between immigration and the belconnen mall) must be kind of loud because i heard it over my music (headphones) and through the window.. the car looked mostly stock apart from the wingless rear end. i didnt get a long enough look (and only from the back) at it to decide if it was a GT/R or not
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4267471
spotted Shell this arvo heading into fyshwick turning on to Canberra Ave. hope i didn't chop you too bad when i merged! i was driving the white subie, which is why it probably looked really strange seeing some idiot waving at you in a totally different car!
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4273264
haha so it was you... I was fairly sure... yeh I did wonder who it was at first with just the arm, but then the head came out the window as well haha :D
No the merging was fine, I always leave a bit of space and let people in at that spot... cos I'm a considerate driver like that lulz
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4274531
Spotted an unmarked black VE SS ute stalking the dara formal last night ..massive cheers the random who knocked on the window and warned us
r33skylinegtst - I've seen a couple of new model lancers as unmarked cars lately, hubcaps and all haha
and followed a mint white 32GTR with gold Volks through fadden and lower chisho yesterday
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4277609
