Definetly Ben. Have some more info on the skyline situation too (as posted by my wanted to buy post), he thinks I may have a collector gasket issue... It will explain the rich under boost and slightly lean on vacuum.
No one unfortunately has a metal gasket. John can't even order one as he's tried many VIN's and part numbers, all turn up being rubber gaskets.....
https://www.sau.com.au/forums/topic/30059-spotted/page/524/#findComment-4312982
Ouch ... not good ... I had a close call this morning have a really shocking wheel alignment at the moment have excessive toe out on both the front wheels and it is causing major understeer at the moment and in this wet weather it allmost caused me to slide into a gutter near the airport on the way to work bloody scary feeling trying to steer around a corner and the car just keeps going straight
https://www.sau.com.au/forums/topic/30059-spotted/page/524/#findComment-4314828
Rossco was that you that I saw driving out of Autotech this afternoon?? That was our S3, I was there dropping off my clutch :)
Sorry to interupt, but S3 as in Audi? I love Audis...there's an RS6 with my name on it if Lotto comes in!!
https://www.sau.com.au/forums/topic/30059-spotted/page/524/#findComment-4318876
Yeah hubby drives a new Limited edition S3 with the recaro seats and stuff. Although I stole it on Friday and got in trouble for spinning the wheels in the wet :)
Nice! Props to a lady who enjoys sinking the right slipper into the firewall!!
https://www.sau.com.au/forums/topic/30059-spotted/page/524/#findComment-4318915
LOL funny you shoud say that... I forgot which car I was driving and the clutch is so light - nearly got the left slipper straight through the firewall too!
https://www.sau.com.au/forums/topic/30059-spotted/page/524/#findComment-4318920
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
