I am always going to keep my first car (my 33) i dont think i could ever part with her, even when i get another skyline lol :blink:
It was sad but wasn't hard to part with because I already had my dream car in the garage.
spotted the gutters at work being a bit higher than i remember haha...not good ....but not that bad.
Oh ouch I hope its not too bad!!
Spotted CeJay today. Car sounds awesome!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4541228
Spotted Gus hitting said gutter at his work ... little bit of paint off nothing serious ... but at least the bar is made from plastic and flexes and not fiberglass otherwise it would have busted it good and proper
They are bloody high gutters I almost hit one myself on the opposite side ... about 30 seconds b4 you ..
Edited by hr32gts
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4541366
Thanks, although my car only looks slightly less dirty now lol.
Did spot a nice 32 gtr on the way home from work today at the kingsford smith / ginninderra drive interesction, gunmetal grey with nice rims, although he didn't look over at me as he was turning, looked like a new canberra car too, had YG---- number plates.
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4542801
Spotted Kat in her phat looking white GTR last night coming out of Hume onto the Monaro Hwy... I certainly hope you werent coming out of the Caltex/Woolies servo Kat!... Bad fuel there :)
I'll lay pounds to peanuts that she wasn't - I'm guessing she has been to the workshop to pick up her baby. And the way you are poking the yukky tongue out, I'm starting to think you've been drinking the fuel from there??
https://www.sau.com.au/forums/topic/30059-spotted/page/553/#findComment-4548688
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
