Spotted EPIC FAIL ....
My R32 skyline .... LOL ...
LHR 17" Chrome rim buckled ever so slightly by potholes near airport and on majura road in 4 places around the rim and is heavily leaking air around the bead of the tyre and was running on rim ...consequently splitting the sidewall of the tyre all round ...
215/35 R17 Silver stone tyre @ $320 per tyre aswell ... not cheap and this is the 2nd time these tyres have failed on that set of wheels ... DODGEY chromes to the bin with them I say ...
And the Epic fail part is I had to Drive home on a 4 stud bloody space saver ... never ever thought i'd ever have to use that tyre but it came in handy this time round ...
Space saver FTW :thumbsup: ...
Will have to take my White 15x6" CSA wheels with polished lip in tomorrow and get a cheap set of 205/60 R15's fitted to get me by until I can afford some nice new 215/45R17 rubber on my good set of 17x7" SSA wheels
around $250 per tyre for the tyres I want ... cant afford that for a little while so cheap 15's will do .... Hoorah for 4 stud and cheap ass tyres
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4705782
Spotted 2! new 370Z's today. nice.
i think i saw one a few weeks ago black or dark grey. at first i thought what was wrong with that 350 then thought maybe a 370. but id have to see it again.
that would have been me, what car were you in? I didnt snob you did I? :blush:
you had just turned onto sulwood. blue over silver VL Calais. i was heading towards weston creek. yes yes you did :(
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4706280
awww sorry!! :D Did you wave?
I think I vaguely remember the VL actually... but I didnt see a wave
no i didnt. seeing as i was in a VL and if i had waved at you you may have thought i was weird lol but now you know so i will next time when our paths cross....
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4707345
If it was around lunch time Kat, them I was either taking the car to Pedders to get inspection or looking for reliable double sided tape for aerial...Pedders told me useless information, nothing I already didnt know.
Spotted a White R34 tailing a bit behind me Thursday night when i was going home. Also spotted that R35 around Mitchell/Gungahlin
Apparently there is 2 R35 GTRs (White) in gungahlin and apparently they are neighbours, but im just thinking that one had come down from Sydney. ??
R33SkylineGtst: Nice to meet you too :)
Hope everyone who went to Coles Express on Wednesday got a free sausage roll...and then discovered who horrible they are.
If you guys want to do a around the town cruise, come to my work as I will give everyone who wants free coffee XD ...or hot chocolate.....I guess
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4708255
spotted on Friday arvo an R32 being driven up the hill out of Queanbeyan (otherwise known as the suspension test track - wink wink), then turning around at the intersection of captains flat rd, giving it the bottle and hitting the limiter - not pretty... (yes, i know who was driving)
i suspect mine got the same when it was in... rev limit for my GTR next time it is there...
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4711691
More hints please!
I spotted a LM Blue R33 GTR a week or so back, gave a wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/566/#findComment-4711708
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
