spotted on Friday arvo an R32 being driven up the hill out of Queanbeyan (otherwise known as the suspension test track - wink wink), then turning around at the intersection of captains flat rd, giving it the bottle and hitting the limiter - not pretty... (yes, i know who was driving)
i suspect mine got the same when it was in... rev limit for my GTR next time it is there...
A month or so back you would have seen my R33 LM doing the same suspension test track run, except it was me driving it with a suspension guy as passenger and it went nowhere near the limiter.
Would be pretty surprised if it was who I think you mean that was giving the R32 a pizzling :P
https://www.sau.com.au/forums/topic/30059-spotted/page/567/#findComment-4712168
Dan you got PM.
https://www.sau.com.au/forums/topic/30059-spotted/page/567/#findComment-4712387
Would be pretty surprised if it was who I think you mean that was giving the R32 a pizzling :D
I spotted you waiting to turn right onto Canberra Avenue, on State Circle a while back.
I think this is my first spotted member, LOL.
https://www.sau.com.au/forums/topic/30059-spotted/page/567/#findComment-4713104
Spotted Zane's 32 (f**k I think it's his car...I'm horrid with names but I know I should know who owns it lol), a black 32 GTST, Silver 33 (if the owner sees this: god I hope your car was warm when you gave it some around the carpark, at least then you aren't as stupid as I thought - only trying too hard), AND a black series1 R33 with NSW plates, whom I haven't seen before, parked just in front of me - all in woden this evening.
https://www.sau.com.au/forums/topic/30059-spotted/page/567/#findComment-4714869
spotted tonight around 5pm, 2 silver r33's in phillip....
1 was out the back of magnet mart and i think an employies... gave a late wave....
the other was accross the road from where auto one used to be/ still is... hasven't paid that much attention... :-)
whoops...
i was the white r33........
https://www.sau.com.au/forums/topic/30059-spotted/page/567/#findComment-4719154
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
