Spotted a blue series 6-8 looking RX7 that managed to slam a lightpole going onto gunghalin drive extension today cops had it all blocked off ...
the pole came down on the rx7 aswell ...
pretty sure those big metal light poles are worth something like $80,000 or something so it was quite a costly crash
https://www.sau.com.au/forums/topic/30059-spotted/page/573/#findComment-4758051
there not cheap! but no way 80K... the stylish ones that we installed in section 84 in civic (new canberra center) were around 14K per pole, with fittings...
sure hope its insured anyway!!!
really sux to hear a nice car coming unstuck like that!
Edited by Randon_I_Am
https://www.sau.com.au/forums/topic/30059-spotted/page/573/#findComment-4758087
spotted really tidy white 33 parked next to me just now, nsw plates. And a maroon s1 33 not too far in front of me lol
saw a maroon 33 with twin tip exhaust (not the stock) hume to gordon and wondering if i was the white 33 you saw cause i'm armed with the yellow and black plates ...
https://www.sau.com.au/forums/topic/30059-spotted/page/573/#findComment-4758557
Haha yeah that was me, we both had that "hmmm I think I know who that is" look :P
ha ha ha yeah ah well maybe next time lol just about to install an apex-i boost controller and talking to ed about getting it dyno tuned again
https://www.sau.com.au/forums/topic/30059-spotted/page/573/#findComment-4758695
clean Maroon R33 series 2 wearing P plates, front mount and Trojan sticker on the rear quarter window driving near Reid CIT this morning
that was me its the cleanest its been in 6 months hahahaha took me long enough to get spotted, where were you?
Edited by Greekos
https://www.sau.com.au/forums/topic/30059-spotted/page/573/#findComment-4760685
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
