Spotted an R32 GTR past theodore onto the monaro this morning. very nice!
Spotted two maroon r33's yesterday on the monaro, one s2 turning off the Queanbo and a s1 behind me most of the monaro (I was in my sis's pulsar - which i forgot to take the P plates off by the way....)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787133
JD travelling in style to work this morning. I was in such a daze this morning, saw the waving and my mind said yep, JD, wave back... My hand took an extra minute to react...
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :D
The old diesel ute has been called many things (especially the time it broke down halfway up the Clyde), but stylish isn't one of them.....
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787393
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :)
Since I drive like a grandma to work, I thought you would have caught me a lot sooner than that! It's always an entertaining scenario in the morning when I have people go flying past me at warp 10 in their Kia's only to stop at the roundabout and then the lights where we turn off..
Haha, poor ute. C'mon, how is it not soooo much more stylish than a GTR, sheesh...
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787473
I was stealth in the Audi. Had dropped my car off at Inline and in a daze my husband turned instead of going straight when we were leaving Qbn so slight detour lol.
Nice pile of tyres at Inline too Reece. Pity they're not the same size as mine I mighta slipped Chris a $50 to accidentally mix them up ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4791290
Spotted Yellow 34 right out the front of erindale leisure centre as I drove past blinding them no doubt.
Also, some piece of shit (pardon the language) thinking he's f**king funny spitting on my car as he drives beside me in traffic coming down erindale drive - HAHA f**kWIT DIDN'T EXPECT ME TO SEE YOU DO IT HUH? BET YOU DIDN'T EXPECT ME TO GET YOUR PLATES AND MAKE/MODEL EITHER?
Good work to the above dipshit, you'll get your own.
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4792380
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
