Surprised no one else saw this. I think it was on Sunday. Totally speculation but I was coming from Belconnen towards Glenloch and I saw a Toyota Turcel that had crashed around where the old traffic lights used to be and was a pretty messed up. Then as I came under the bridge to turn right towards Tuggers, there was an R32 GTST totally munched sitting in the filter lane to Tuggers. When I had seen the Turcel I thought it a bit strange that such a big accident with lots of skid marks and only one car and it seems to me, Mr Skyline (was a reasonably young guy) tried to do a runner, but couldn't get far. I hope not and like I said it is pure speculation, but he had driven a long way from the accident for it to be not on purpose if you know what I mean...
Anyone know any more?
https://www.sau.com.au/forums/topic/30059-spotted/page/591/#findComment-4890985
From my desk I can see a blue automatic R33 with GTR badges on it, my car next to that and then a VSpecII 34 next to me :P mini-meet!
Are the owners on here??
hey mate - good to meet you the other day... did you end up finding out who the blue "GTSR" driver is?
https://www.sau.com.au/forums/topic/30059-spotted/page/591/#findComment-4894520
hey... ive spotted you so many times.. at least 3 times a week. I think you even followed me home one day this week. I drive a white chaser on R33 stockies with the exhaust scraping to road :( Your car looks so good... and its totally stock!!
Also, spotted sl33py in the mall :P
Also, spotted a silver R32 GTR at the lights on Nettlefold and Lathlain street at 0656 this morning. The car has red car seat covers and a very short driver
Edited by nerm
https://www.sau.com.au/forums/topic/30059-spotted/page/591/#findComment-4895952
Spotted Yellow 33 today on Belconnen way... Yesterday Spotted a white 33 heading down Kambah pool road there were L plates on my skyline because I was teaching my cousin to drive, I drive better than that lol....
https://www.sau.com.au/forums/topic/30059-spotted/page/591/#findComment-4896385
pfft, you weren't even on a race track and you are making up excuses :devil:
Hey, if you were driving with someone that has only attempted driving a car 5 times than decides they like to accelerate hard because they like the turbo but forget about the clutch, to steer or change gears when they get distracted by people beeping and whistling whilst cornering than you would understand... LOL :P It was good fun tho
https://www.sau.com.au/forums/topic/30059-spotted/page/591/#findComment-4896699
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
