Spotted a mirror image Silver M35 Stagea on Parkes way yesterday morning 830ish. Felt weird.
I spotted a silver M35 in fyshwick this arvo at about 5:40 on woolongong st as I was leaving work. Was also wierd... I was thinking to myself "what the hell is someone doing driving my car?? especially since the turbo is blown atm!"
First M35 I've seen getting around since I've had mine.
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4981186
all black r33 with black wheels (looked frickn tufff!!!... for a 33 :worship:) coming out of bruce around 1245 yesterday afternoon.
also a silver r33 with a pearl in it and chrome multispoke rims near immigration in belconnen at around 1235 yesterday afternoon
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4981922
Spotted a 4 door R32 with P-plates and a Federal sticker on the back window (same as the one now plastered on mine lol) at the Shell on the Hume yesterday arvo. Had quite a loud exhaust.
Possibly Rebecca (Michelle G daughter, I am pretty sure it has a federal sticker on it)
p.s. This is melly
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4991955
p.s. This is melly
I thought of her actually, but I thought the car looked different... but I could be wrong :3some:
Was she at the OP thing that Reece & Zane were at?
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4992144
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
