for sure, cooper is a rad name. You could even glue white fur all over it to be more like the real thing lol.
that one's only for "first jobs" ya know, the ones the tax man knows about... Not the little something on the side :-P
Edited by Randon_I_Am
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5008936
how good is the clyde now its been re-sealed! And they must have put a phone tower up too, because i get reception there now :-)
spotted a ferrari something, lotus exige, nsx but still no skylines in melbourne. Maybe today's adventures will change that.
Happy new year everyone!
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5010303
meh am I the only one who finds the clyde boring? not that interesting a road
I just don't think you have ever got to drive it fast enough :P
In saying that, you don't have to go ridiculous, speed limit can be plenty, just you hardly ever get a clean run at it
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5012120
I got a great run on the way down... managed to get to the front of the pack, so there was no one holding me up :P
Today on the way home wasn't great though. Got stuck behind slowarse cars :iluvff:
That was me. :banana:
oh cool, dont think i've spotted you before!! Did you see my car across the road in teh carpark?
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5012181
My last trip i got a clean run both ways up and down the clyde, it really is a fun piece of road!!!
for some reason tho my rear wheels always go faster than my fronts, and my car seems to not go straight, coming out of government bend going up hill... :P
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5012387
I just find roads like Macquarie Pass a lot more interesting and the snowy mountains hwy from bega
https://www.sau.com.au/forums/topic/30059-spotted/page/600/#findComment-5012409
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
