*Tis Melly*
spotted a pink 33 wearing sau stickers in the underground car park at canberra center (i had to park in front of you)at around 1:20 pm
Yippeeee Spotted... I was going to Physio Blah :D
Actually that reminds me. Spotted Melly on Gungahlin Drive yesterday bout 5ish.
Also spotted a white and a black R34 driving along Northbourne at Lunch time yesterday as well.
And finally, a maroon 33 on Moore Street just before 1 this afternoon.
I've actually had a big week of Skyline spotting!
Yay spotted again!! Yeah, going home from work..
I always see heaps of skylines between home and mitchell but forget to post.. Maroon 33 a see often in Mitchell...
https://www.sau.com.au/forums/topic/30059-spotted/page/623/#findComment-5244681
Spotted a silver r32 gtr on coulter dr, had a chat at the lights lol, think his username was silverslider? Also spotted white 4 door r32 in kaleen
Yeah lol, wasn't payin attention at first had the music up a bitt when i saw you the first time at the other set of lights, traffic was a bit noisy at times then saw a that red 34 GTT fly past aswell.
https://www.sau.com.au/forums/topic/30059-spotted/page/623/#findComment-5246201
Spotted a silver R32 GTR turning off Horsepark Drive into Forde at about 9am this morning.
And an R33 with carbon fibre bonnet parked near the Gunners shops on both the way to and from work today.
my 33 is always on the street outside the new college site. Was probably it.
https://www.sau.com.au/forums/topic/30059-spotted/page/623/#findComment-5251640
Ooooh I was wondering if it was yours! Looks good! :cheers:
Haha thanks. Alot of people have had trouble recognising it. I basically changed everything except the colour. Finally got it how I like it. Will be pulling it of the road in sometime, just decided on and put forward plans for an rb25/30 complete forged rebuild and conversion. Turning my garage into a workshop once again.
https://www.sau.com.au/forums/topic/30059-spotted/page/623/#findComment-5252026
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
