^ ^ Apparently that car is running close to 1000hp, coz I talked to the owner not long ago, I think he's around the jerra/qbn area?
Spotted a very clean looking gunmetal r34 gtr in fyshwick around lunchtime, they probably thought I was odd as I waved my kebab at them :/
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5767851
saw 2x R33's at supercheap tuggers at lunch time.
one was black with gold speedy envy's and a big gold rushhour sticker
the other was a yellow acid metallic colour sitting low with 19-20" black and machined rims (maybe zenetti)
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5778910
eww
lol
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5779305
eww
lol
+27ty
There are some fkn horrid cars down this way...saw a dark green JZZ31 (non turbo) soarer this morning, Not only did if have the ugliest kit I have even seen on a Soarer, it wasnt painted, had some stupid aluminim T wing and 2 HUGE cannons poking out underneath and standard 15" wheels with what looked like 185s all around.
There is also a mint green R33 with not a straight panel on it, front bumper hanging loose on one side and has a Veilside rear wing, but with out the airfoil part of the wing...so it just has the 2 sides sticking up off the boot lid.
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5781135
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
