the orange R33 in question ive seen with a blonde driving has a URAS style bodykit and ducktail spoiler. see it most weekends around woden area. it was all good til i saw her spark up a smoke and start puffin away with the window 90% up :sick:
Black rims? If so I know her.
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5846291
saw 2 dark blue R32 GTSTs this afternoon within 2 minutes of each other.
one came off hindmarsh onto monaro highway and went into newcastle street, had a silver looking bonnet and the second i saw turning onto morshead drive from the monaro highway, both at about 4:45pm
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5846459
spotted a white R33 GTST at woden about lunch time and just then saw a white R34 with HIDs and dark wheels driving past on the opposite side of hindmarsh drive to me. just before the r34 i saw a silver M35 stagea too
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5849567
i think i saw MIVEC's evo last night in civic, parked near the police station that's across northbourne from the mooseheads car park at around 10:30 -11pm i think
Yup that would have been me!
That cop shop does funky things to my car's immobiliser too, similar effect to Black Mtn.
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5849679
Blk Mtn Gaurds have instructions as it happens alot - I was one a year or so ago.
Some cars just have to roll part way down to get going - FTW.
If you hve one of those reflective sun visors that can help.
Just a sheilding issue.
PS. the cameras in the lifts DO work. Thank you to all the ladies who thought they'd give us a jolly :P
The extreme overwheight mother who thought she'd lift her top - NOT FUNNY !!! A few of the young gaurds are still receiving therapy!
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5850084
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
