the orange R33 in question ive seen with a blonde driving has a URAS style bodykit and ducktail spoiler. see it most weekends around woden area. it was all good til i saw her spark up a smoke and start puffin away with the window 90% up :sick:
Black rims? If so I know her.
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5846291
saw 2 dark blue R32 GTSTs this afternoon within 2 minutes of each other.
one came off hindmarsh onto monaro highway and went into newcastle street, had a silver looking bonnet and the second i saw turning onto morshead drive from the monaro highway, both at about 4:45pm
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5846459
spotted a white R33 GTST at woden about lunch time and just then saw a white R34 with HIDs and dark wheels driving past on the opposite side of hindmarsh drive to me. just before the r34 i saw a silver M35 stagea too
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5849567
i think i saw MIVEC's evo last night in civic, parked near the police station that's across northbourne from the mooseheads car park at around 10:30 -11pm i think
Yup that would have been me!
That cop shop does funky things to my car's immobiliser too, similar effect to Black Mtn.
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5849679
Blk Mtn Gaurds have instructions as it happens alot - I was one a year or so ago.
Some cars just have to roll part way down to get going - FTW.
If you hve one of those reflective sun visors that can help.
Just a sheilding issue.
PS. the cameras in the lifts DO work. Thank you to all the ladies who thought they'd give us a jolly :P
The extreme overwheight mother who thought she'd lift her top - NOT FUNNY !!! A few of the young gaurds are still receiving therapy!
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/671/#findComment-5850084
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
