Just went to get some fuel and spotted that bright orange whale with a big bodykit on it which is driven by a p plater chick I think? A yellow 34 I think 2 cars behind on athlon and then a black 32 on hindmarsh turning onto athlon and then eiji as well haha
https://www.sau.com.au/forums/topic/30059-spotted/page/734/#findComment-6316764
Pretty sure I spotted Zane this morning exiting the highway to head onto Hindmarsh.
Silver R32 with dark 32GTR looking wheels on hindmarsh about 8am.
Silver r34 gold wheels and possibly spoilerless on sulwood about 5:30
Both were probably me *waves* hi guys!
https://www.sau.com.au/forums/topic/30059-spotted/page/734/#findComment-6318372
Spotted my car on the road again (technically unregistered, on a permit) today. Finally got the engineer's certificate.
Now when I can afford to register it again, I'll see what those f**kheads at Dickson want to pick on this time.
https://www.sau.com.au/forums/topic/30059-spotted/page/734/#findComment-6320154
Just spotted a silver 33 in belconnen, i followed it for a bit then turned off towards Holt though I was in the cressy so I didn't bother waving as i turned off. So good to be driving the couch again.
https://www.sau.com.au/forums/topic/30059-spotted/page/734/#findComment-6320291
