I spotted a 32 GTR turn off just after the bridge near parliament house.
I managed to drive over the bridge just in time to hear him open it up as he went under.
Also a 33 could have been a GTR as it had the wing. Also had forsale sign. At the roundabout turning on to gunderoo drive
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6321434
spotted a silver R32 4 door in narrabundah that appeared to have plexiglass windows and he was having a bit of fun showing off. I also spotted a black R32 gtr on hindmarsh drive along with a yellow R34 gt-t going the opposite way around 1:30
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6324562
showing off how?
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325528
Showing off by letting
Your mate take ur car for a spin without u in the car...last time I let him drive.
I just spotted a silver r33 gtr on hindmarsh dr was gunna wave but was in my bogan spec commodore did enjoy watching it race a black z06 corvette pretty sure the corvette didn't catch the gtr either which is always a good outcome
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325671
Hmm 4 doors seem to be sprouting in Canberra. Spotted shell near kambah caltex servo around 540 . PS your front left headlight doesn't work. We were in the Kia.
haha yeah I know... put some new globes in and now the earth wire thingy has fallen out and won't go back in. Bought some little electrical things and r32-25t is going to fix it for me tonight.
I don't remember seeing a Kia, but then again I wouldn't really have been looking :P
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325771
Delayed spotted: went to the movies on Monday night in Woden. Saw a neat white 32 GTR. When we came out, it was warming up; I wanted to go up and say props but figured I'd look like an old man weirdo stalker, LOL!
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6329888
Pretty sure It's the same one but it's always there.
Parked out the front of the shops
Doesn't seem to be anyone on here
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6330024
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
