I spotted a 32 GTR turn off just after the bridge near parliament house.
I managed to drive over the bridge just in time to hear him open it up as he went under.
Also a 33 could have been a GTR as it had the wing. Also had forsale sign. At the roundabout turning on to gunderoo drive
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6321434
spotted a silver R32 4 door in narrabundah that appeared to have plexiglass windows and he was having a bit of fun showing off. I also spotted a black R32 gtr on hindmarsh drive along with a yellow R34 gt-t going the opposite way around 1:30
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6324562
showing off how?
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325528
Showing off by letting
Your mate take ur car for a spin without u in the car...last time I let him drive.
I just spotted a silver r33 gtr on hindmarsh dr was gunna wave but was in my bogan spec commodore did enjoy watching it race a black z06 corvette pretty sure the corvette didn't catch the gtr either which is always a good outcome
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325671
Hmm 4 doors seem to be sprouting in Canberra. Spotted shell near kambah caltex servo around 540 . PS your front left headlight doesn't work. We were in the Kia.
haha yeah I know... put some new globes in and now the earth wire thingy has fallen out and won't go back in. Bought some little electrical things and r32-25t is going to fix it for me tonight.
I don't remember seeing a Kia, but then again I wouldn't really have been looking :P
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325771
Delayed spotted: went to the movies on Monday night in Woden. Saw a neat white 32 GTR. When we came out, it was warming up; I wanted to go up and say props but figured I'd look like an old man weirdo stalker, LOL!
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6329888
Pretty sure It's the same one but it's always there.
Parked out the front of the shops
Doesn't seem to be anyone on here
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6330024
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
