That was no doubt me on Horsepark drive. ^_^
I think I've seen that blue R34 you speak of. Looks a bit rough around the edges? :( Is it actually a real GTR? I thought it just had GTR badges etc lol
Or maybe I saw a diff one...
If you see some random in a bright red beema waving then it's me lol :)
At least you didn't cut me off at that intersection like someone did this morning - was most unimpressed and when it happens there's NEVER anyone behind me!
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6860002
Spotted Jimmy on the GDE this morning. Probs going to be a common spotting with my start time over next few weeks while I'm working in Woden.
I get around :D
I'll have to keep an eye out for this red 318 then
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6863796
To the f**khead in the acid rush Ford ute, what a lovely person you are. First you merge onto the GDE tailgating and abusing the person you're behind, then you do the same to me while I'm overtaking a truck (I was doing 15kms over the speed limit I might add, so I wasn't dawdling) and then you give me the bird after you get past me.
Whatever issues you have with your lack of ability to function in normal society and small penis, maybe you should keep it off the road, f**ktard.
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6864775
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
