Spotted the same Black R33 I saw in Belco today, on Lhotsky St Charnie at 6:15pm.
(I think it may even be the one that young Andrew fella had before his Mum Sold it on him)
Nope wasn't me
last time i drove was friday night
Saw a White R32 GTR in woden on hindmarsh drive with black front bumper around 8am
Edited by 5hiv
https://www.sau.com.au/forums/topic/30059-spotted/page/972/#findComment-7449925
Silver S2 R33 at Charnie Maccas at 7:37pm.
On my journey to and fro Nambucca in the past week, I saw a Silver S1 R33 with dark / carbon? bonnet and a Black R35 GTR.
By Far the most imports I saw though were Elgrands. Heaps of them. :O
https://www.sau.com.au/forums/topic/30059-spotted/page/972/#findComment-7458607
