Jay...i'm bit late reading the news but I'm so sorry to hear about ur car :) :) :)
and i will vouch for the careful driver thing!! you were always the slow coach taking it easy up the back, on cruises i went on hehe :) But seriously, don't beat yourself up....accidents happen...at least you have done the right thing and are fully insured, makes things a lot less stressful for both parties..
hope the x-trail wasn't my mum LOL :Oops:
https://www.sau.com.au/forums/topic/30059-spotted/page/28/#findComment-846952
Thanks Shell, Nope, pretty sure it wasn't your mum, unless you were adopted by an Asian family ! :)
Car get's towed off this afternoon, the assesor wanted to have a look at the car in a workshop while up on a hoist. Should find out in a few days if it's going to be repaired or if it's a right off......
J
https://www.sau.com.au/forums/topic/30059-spotted/page/28/#findComment-847166
GTS_DUY, that could be Kryostaisis.
On another note, and this could be just me being mega paranoid (so shout me down if I'm being dumb :) ) but I'm not sure we should post spotteds of cars which are parked for extended periods. E.g. posting a spotted about a car of the guy who lives down the road or whatever.
I guess I just don't want some wanker combing the forums to get good spots for targets...
https://www.sau.com.au/forums/topic/30059-spotted/page/28/#findComment-847949
wat are u guys talkin about i saw that 32 in belco near pizza hut its crazy the airbrushing is crazy and the spinners look mad i would never toss em i love that car its up with the best
also saw a r31 the other day all the mods were mags and springs numberplate was "godzila" i would say its worth more than the car !!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/28/#findComment-848730
[quote GTS_DUY.
On another note, and this could be just me being mega paranoid (so shout me down if I'm being dumb :P ) but I'm not sure we should post spotteds of cars which are parked for extended periods. E.g. posting a spotted about a car of the guy who lives down the road or whatever. I guess I just don't want some wanker combing the forums to get good spots for targets...
I'm agreeing with GTS_DUY-maybe only mentioning short term parked cars will lower the attention given by lower life forms...like car theives,bad police(there are so some good ones out there!)etc,etc....
https://www.sau.com.au/forums/topic/30059-spotted/page/28/#findComment-849121
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
