Yay!!!!!
Ive been SPOTTED!!
yea that was me....i hope... Purple with body kit?????
Yea thats mY spot! :wassup:
YAY i knew someone onhere had mentioned a purple R32! :P
and yes it had a body kit...a nice clean one, not a full on over the top one - sound like yours?
that's the BEST place to park, nice wide spot and only one car next to you :)
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-982950
YAY i knew someone onhere had mentioned a purple R32!  :cheers:
that's the BEST place to park, nice wide spot and only one car next to you :D
Yea thats me:D
Yea, wasnt too sure about the kit, Friends like it , and they tell me to keep it. so its gonna have to stay for a bit.
"Spotted a purple R32 GTS-t around Tuggeranong at about 2:50.... looking/sounding good."
Oh SIC!
I was spotted again...
Yea was kinda bored at home so felt like goin for a drive...
Thanx Mate , ;)
Kinda wondered what people think of me car, and whether it sounds ok...
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-983466
spotted a gunmetal R32 (could have been a GTR not sure) at 2pm... i was on Beasley St Mawson waiting to turn onto the Rd that goes past Isaacs, gave him a small wave as he went past, no response :P
caught up to him at the lights at the hospital, was an asian guy...he still didn't wave, looked a bit confused actually LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-983743
spotted... a datsun tearing me a new asshole because my clutch is stuffed and he tried to take advantage of it :) 7000rpm and one dirty as smell later, i finally got moving... doh :)
On a good note though, hks twin plate arrived on tuesday :P
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984060
Sorry shell, didn't know you waved, Im always daydreaming, Hi
anyway :( , Ive only had the gtr about a month, have had no
end of headaches with engine and turbo problems, should all be
sorted in the next couple of weeks though. woohoo!.. Ive been
spotted already :headspin:
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984418
anyway    :)  , Ive only had the gtr about a month, have had no
haha that's cool...nice to see you join up here anyway - welcome to SAU! :P
sorry to hear you've had problems :P
where did you get the car from?
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984790
Spotted a white R32 in Queenbeyan, the driver was watching the car as he went past, i waved but dont think he really cared. was probably getting over the shock of seeing my mum behind the wheel...
Also spotted a yellow R33 series I with stripes up the middle. No offence to the driver but i'm really not a fan of the stripes...
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-985888
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
