Spotted an R34 GT-T,wingless and yellow,with white wheels(I think I've mentioned the same car a few motnths ago...)boosting thru. braddon last night.
Waved @ Amaru's car as we first got into Lonsdale Street-dude:when's the car going under the knife?!
And a white R32 w/black rims and a full rollcage joined in some "spirited cuising" home along Canberra Ave. with a few of us last night.Without giving up too much attention grabbing info',I know the drivers' name is Phil-and ,if he's on the forums-drop me a line!Neat l'il beastie!
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-985945
jayson yea the R34 GT-T has to be the one thats always outside transact building the guy seems like a bit of a tool ??? may be wrong but was in the lift once and i just asked so its a GT-T and he was like yea. in a voice like why the **** are you asking ??? anyways it is an ok car though i guess
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-985983
Seems you spot me religiously every Friday night in braddon :( its about the only time of the week I take the car out hehe... car goes under the knife on Monday so it will be at Ed's for an indefinate amount of time :( (clutch arrived, still waiting on those damned camshafts, and some other stuff coming with the camshafts).
I hope to see all of you fellas at the syndicate dyno day next week too, 28th august, 10:30am at autotech services.
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-986098
Spotted a white R32 in Queenbeyan, the driver was watching the car as he went past, i waved but dont think he really cared. was probably getting over the shock of seeing my mum behind the wheel...
was probably me. the 32 have a kit on but stock wheels? thats me. i see lots of r33's around queanbeyan and i try to wave to some but im usually taking off when i see em.
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-986239
spotted: last night, turning off into a side street from knoke av in gordon, a nice sounding wine red R33, i was going straight but turned left so i could have another look lol, i was in my mums excel though so he wouldnt have noticed me.
also spotted this morning, stock black R33 cruising down namatjira dr. could have been leech's dad driving? not sure though.
and on drakeford dr heading city bound a very clean wine red R32.
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-986771
wtf i highly doubt it i have only let him drive the car once hehe i think u mean p1ater :( where is namatjira dr the only place i have been is between my house and g/fs :D
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-986838
the dewinged R34 GT-T with white wheels pulled up behind me at the lights. gave him a big wave out the window: nothing.
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-987870
yea that guy is he thinks hes the mac daddy of mac daddys :D
anyways on um monday i spotted a R33 with like racing lines/decals stragiht over the top of the car i wasent a huge fan of it but it was getting dark so i couldnt see it properly it was a yellow one.
also when going along the main oxley road and spotted a black r32 gts-t
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-988272
spotted on monday evening a black R33 behind me driving my dads statesman, just b4 the turn onto the yellow tunnel on the parkway heading tuggers bound. stayed behing us for a bit then gave it a blast passed me just after the tunnel.
also spotted my car getting towed this arvo after fu**ing it up pretty good, ive wrecked the battery, may have fried the ECU, alternator and starter motor, plus some other stuff.
Then the front bar getting snapped as it was put on the truck........i swear to god tow truck companys must HATE me!!! thats 2 in a few weeks......ITS A NIZMO BAR FFS!!!!!!!!!! im gonna cry !!!! ive had it!!!!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/51/#findComment-988792
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
