That was no doubt me on Horsepark drive. ^_^
I think I've seen that blue R34 you speak of. Looks a bit rough around the edges? :( Is it actually a real GTR? I thought it just had GTR badges etc lol
Or maybe I saw a diff one...
If you see some random in a bright red beema waving then it's me lol :)
At least you didn't cut me off at that intersection like someone did this morning - was most unimpressed and when it happens there's NEVER anyone behind me!
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6860002
Spotted Jimmy on the GDE this morning. Probs going to be a common spotting with my start time over next few weeks while I'm working in Woden.
I get around :D
I'll have to keep an eye out for this red 318 then
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6863796
To the f**khead in the acid rush Ford ute, what a lovely person you are. First you merge onto the GDE tailgating and abusing the person you're behind, then you do the same to me while I'm overtaking a truck (I was doing 15kms over the speed limit I might add, so I wasn't dawdling) and then you give me the bird after you get past me.
Whatever issues you have with your lack of ability to function in normal society and small penis, maybe you should keep it off the road, f**ktard.
https://www.sau.com.au/forums/topic/30059-spotted/page/836/#findComment-6864775
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
