Some purist says, R33 is the best in term of power and ride & handling outshine its other sibling. I read in few mags confirming the R33 as the best Skyline with RB engine ever. R32 was perhaps the one that changed the perception of Japanese Sport car through out the world, R33 polished and enhanced it to next level. R34 was said to be too heavy, too tech savvy and being call Play Station Generation's car.
In Malaysia, R33 is very2 less respected and 'ashamed' compared with R32 or R34 due to the similarity in its design with Perdana wannabe Skyliner.
R31 is almost unheard before as it was marketed for Japanese market only. I've been told R31 is a respected beast till today in Japan as it conquered Japan domestic races and underground races during its heyday.
This really just comes down to personal preference.
R32 GTR claimed its name in bathurst back in the day and still till this day seems to break records against its youngest brother the R35 GTR
I prefer the interior of the r33 and r34 over the r32.
I would buy a R34 GTR over my 32 GTR anyday but I cant afford too :)
so yeh i think each one has its pros and cons.
no car is ever perfect
my 2cents
  • Like 1
my 2cents
R32 & R33 the best car.?
Best on a budget. I think you'd be hard pressed to find many peoplw who'd say that a 33 or 32 would be better than a 34, but you'd also be hard pressed to find anyone who can afford a 34, since they cost 50K AUD or so.
ah so itsa GTR's only being talked about here? Makes a bit more sense then i guess.
I'd agree with Sarumatix's quote although do not know much about the r31 the descriptions of the 32/33 and 34 seem pretty spot on to me
They have the same engine, with more torque as each new model came out.
The R32 and R33 GTR have the same engine.
Was probably tuned to have a bit more torque but that's about it.
Any car with a MFD, ppl say it's to savvy.
Playstation Generation cuz all the kids who play Need 4 Speed Underground, don't have the chance to drive a real R34 GTR, they praise it in the video game like crazy.
R32 and R34 GTR's look better.
Dispite it's 'grandpa' styling, it took the Skyline 1 step closer to the GTR's.
For GTRs my personal opinion is the R34. Nissan studied what they did wrong with the R33 (too heavy, less GTR appeal) and tried to make a car that was closer to the R32. Remember at the time the NSX was out and was technically a superior car to the R32 and R33. Nissan had to come out with something better and the R34 was the end result.
Next is the R32. It just looks better than the R33, lighter and tossier. The muscular lines is what started the GTR appeal in my opinion, the R33 had less of it which looked more like a Falcon or Telstar. The R34 took aggresive styling to another level.
I have less knowledge of the R31. I watched them raced in Group A racing in Australia with George Fury at the wheel and enjoyed watching the blue/white/red cars take on the locals (which they did very well). I think that was when I became a fan. When Godzilla came it was like the missing link of Australian motoring. That was how significant the R32 was.
It seems that I'm not a fan of the R33 because of the styling. I think dark colours like black or midnight purple with offset rims suits them best.
HR31 feels antiquated to drive IMO especially compared to the R32, also feels like you're sitting on the passenger's lap since it is quite squeezy inside.
Depends otherwise on whether you're comparing GT-R or not, R32 w/RB25 is the ultimate Skyline IMO
I have had a 32 and a 34 gtr and both were brilliant, the 34 certainly had a much nicer interior.
I struggle to be engaged by the 33! I am surprised that any purist would pick this vehicle as their
weapon of choice. Especially with models like the 34N1, nur, or aus delivered 32 in the mix.
Aren't we glad that it's the NISSAN MOTOR Co. that conceived > designed > R&D'd > manufactured all of the above?
I know I am!
I think somehow, that Carlos Ghosn has been!
:domokun:
:rofl2:
I thought Nissan revised a few of the ancillaries with each revision of the GTR.
One that springs to mind is the bearing to the oil pump, if i recall correctly, the bearing (or something) is too small on the 32 and is prone to screwing up and causing oil supply issues.
That said was a while ago that i read that... so i could be wrong.
Yes, I too have read about that.
The R32's weak oil pump drive collar, which tended to fail in higher power applications.
So when highly modifying a R32 GTR, that will need attention to.
For stock, light and mid modifications, it is fine.
It was fixed in the R33 GTR, with a wider collar.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
