  • Replies 246
Posted Images
hey Ariel - what do you do to the cast alloy bits before welding in terms of prep? - I always find alot of impurities coming out of casts when welding.
We have an acid at work, it's basically mag wheel cleaner (I work for a radiator shop) I sand the runners about 5-10mm down from where i'll be welding and dip the who9le runner into the solution and clean it off.
I have 0 issues welding cast. I only use 5356 for cast welds, 4043 for everything else. My cast to runner welds are 5356.
http://skeleton.net.nz/~oiad/skyline/plenu...25/P1010704.JPG
like alumi-brite?
basically a sulfuric acid solution ?
Yeah, Kind of.. Think of it as an "exfoliator" for aluminum. It heats the metal and pushes all the crap out. We use it every day, worth its weight in gold.
It does dull the finish, though.
We use glass beads at work for sandblasting, Not good for welding aluminum unless you grind the area after sandblasting.
Hey Ariel,
just letting you know that when you did the mount for the throttle cable, you did it at the wrong angle so when the throttle cable is mounted to the TB, its at a weird angle and needs to modded. the cable is rubbing against the throttle body mount and in time will cause it to fail.
not happy about this as i did give you the TB to trial fit before welding and now i have to take the plenum off and pay someone to fix it.
This is all for the weekend's updates....3 on the right are the race version rb30 and 3 on the left are street version rb30. Both will have billet fuel rails and 80mm billet throttle bodies
Final round of the go karting season tomorrow so I have to get the kart ready tonight and up early tomorrow morning. Lucky the track is only 5 minutes away....
  • 2 months later...
I just realised it has been 2 months since I last updated.
Here is something I done this weekend. RB25RV (Race Version) with R33 RB25. I just have to finish off mounting the fuel rail next weekend. Also attached is a pic of another one I done a while ago R32 RB25.
There is plenty more coming over the next couple of months......it's the business I have ever been. The best is a complete custom FE3 (Mazda) 2.0L looking to make 1200hp and aiming for the 6 second region.
Cheers,
Ariel
This morning's update....finished the Race Version RB25.
This afternoon I might start on the RB30 Race Version and the Mazda FE3 tomorrow....that's if this 40+C heat stays away.
Then there is the bellmouths for the next 6 weeks or so...... :thumbsup:
This weekends progress. Firstly the RB30 Race Version, complete and ready for delivery. It's going in a Holden FC Ute…..nice choice.
…..and this is for an up and coming Pro Compact 4 cylinder front runner. It was picked up today . The FE3 which should be packing some serious punch.
This is my favourite photo
Next weekend is the RB30 Street Version group buy.
Happy Welding,
Ariel
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
