  • Replies 246
Posted Images
Hey Brad, I'll shoot you a PM in a couple of months and if you still have it we can go from there. I'm just in the middle of paving out the back so have no funds, but it doesn't stop me from dreaming. rolleyes.gif
What model is it and price etc - would you send to Perth? Send me a PM if you wish.
Anyway, enough welding talk and more welding action....here are some photos of some recent work.
I am doing some standard replacement parts for VL's (under a new business name, Red Star Fabrications) at the moment as well as custom made aluminium parts for the engine bay. In order of the pics, they are:
- fuse box cover
- power steering fluid canister
- fuse box replacement catch can and surge tank
- mixed bag of goodies lol
I will be doing some other goodies as well. I have custom made catch can to sit inline with the bottom of the radiator, custom made intercooler with diffusers in the end tanks, replacement fuel tank, complete one-off rb26 intake manifold.......so keep an eye on this thread. This is just the beginning of new things to come :action-smiley-069:
Happy welding,
Ariel
....a few from the weekendas promised. This is all done using straight, 100% argon.......BRING back my helium mix PLEASE!!!! My duty cycle went down the sh1tter!!!
XR6 "Race Version"
and last but not lease, please, please do not ever charge a cusgtomer if you weld like this. This customer has come to me for his 3rd intake manifold.The previous have both cracked and leaked!!!
Isuzu G200 LPG Turbo which will incorporate "Nitrous pro-flow' burst panel
They have more problems then that, the plenum split. I just got pics.....hardly any penetration of the material. Poor material preparation, poor welding technique, not enough heat, material not cleaned before welding...the list goes on.............
I will be using 6mm and most probably making 2 passes over it, finishing it off with a weave or "walking the cup" style bead. I have done it before on another LPG plenum made of 10mm...that had 3 passes over it and turned out absolutely mint.
I can't deny that I have. Having said that though, this was all prior to me welding them which has been for the past 2 years or so.
I did make some design changes as well to help sort the problem out since it has only really happened to ones I was making some 4-5 years ago.
I actually offer a lifetime warranty as such to continue supporting my customer base.
Why do you ask?
yo ariel, how much do you charge for that catch can? (with slip on hoses, not threaded fittings) & do you still make the custom fuel rails to suit 14mm injectors? i think they can work with the neo injectors if you just get the right o ring & grommets in and it will fit. (another member did it with a HKS copy rail - are your designs same as the HKS one?) cheers
No worries BR, whenever you are ready, just let me know.
Elvis - catch can is $200. Not sure of what other memebers do, I don't really copy things. I can only make the rails for 11mm or 14mm oring injectors. I may need the complete manifold since it is a NEO and I dont have any of those handy.
Ariel
  • 1 month later...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
