  • Replies 246
Posted Images
no worries at all. Everything has been put back because it was confirmed this morning that my welder parts went to Mexico.....yes MEXICO!!!!!!!
Anyway, it might tie in nicely because I have a car coming down shortly that you may have some work from which you can take a look at while I teach you how to weld LOL....just messing with ya!
Yeah when I drop my car off to ariel, ill get him to weld some dash fittings to the rocker covers then if you wanna take the rocker covers, exhaust manifold, dump and rear turbo housing, Craved, and throw some of your coatings on them that would work out good!
No worries Joel
let me know when you are going to take the car over to Ariel and we'll tee something up.
  • 3 weeks later...
Finally a bit of an update....have been flat out getting back on track after the purchase of a new welder. Only the surge tank and turbo flange have been done with the new welder.
Apart from plenums for 4G63, RB20, RB20 (in matt black shades.gif ) , RB30, SR20, G200 I thought I would post up some pics of the kind of work there seems to be a bit of a demand for. The plenums aren't slowing down, I just put the word out there that I can do this kind of work and people seem to catch on.
Turbo Suzuki Swift GTI - weld exhaust manifold, weld fuel lines, build radiator end tanks and mounts as well as modified radiator support to mount it & intercooler piping
Intercooler for VL Turbo - it's one massive mofo
Welding of new new t3 flange to chinese exhaust manifold
Twin 044 fuel pump undercar surge tank for VL circuit car - coming soon for R32's :thumb:
To keep this thread going, I will have pics of the plenum work I have done recently over the weekend since they are being finalised for delivery.
Happy Welding,
Ariel
I have a CA18DET 1200 ute being towed up here from Canberra this coming week, you can bring your car up after that if you like :thumbsup: and then an R31 (don't worry Joel, I thought I would squeeze it on before your car tunrs up :whistling:
Edited by ISL33P
Dam.....what does it need to get running? Can I help out with it if it comes here?
Junkey (has a quite giggle) - you mean the end tanks for radiators and intercoolers? If so, no. Just measure them, draw it on the sheet and cut away
you "could":nyaanyaa: I am going down to Canberra either this coming week or next week to check out another job so I might aswell come past and have a look at it and see how much i can do with some "templates" maybe enought to get it driving. If you like, pm me your number and I will give you a call when I am heading down
I will be making one for the 32's as soon as I get mine back.
26 plenum is coming along, a little slower than expected but I will definitely have one installed in a car within a month and that's when the first pics will come out :banana:
Considering the inside size of the flange was similar and honestly the customer actually didn't give a sh1t since it is for a junker, he wasn't fussed.
There was absolutely no warping, not when you weld it I like I do :)
Haha fair enough mate was just curious cause I need to do the same thing to one of my manifolds cause my turbo is t2 not t3 so really just after a second opinion of some that has been there before
Haha no rush for mine man, dont wait up for me!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
