hey guys, ill try to keep this short.
Basically i recently got my car back after a big build (rb26/30, gt35r, top mount, ect ect)
and ive noticed how hot it gets when im driving the car.....i realised that theres alot of heat comming from under the dash (where the pedals are) and the air con vents. I assumed it was because of the heat the engine was producing. i also had alot of issues with the water temp hitting 110c sometimes.
so i spent a good amount of money ceramic coating the entire exhaust side. Including manifold, turbo housing, dump pipe ect. the only thign i didnt coat was the wastegate (hard stuff to coat without dismatling the thing). I even bought a new Koyo Radiator to help with water temps.
But nothing changed.....i feel like its gotten hotter.
The only thing i can think of is that i am currently using a screamer pipe....but it never was an issue before the build, then again i wasnt running a bit top mount.
have you guys got any ideas?
https://www.sau.com.au/forums/topic/304229-really-hot-inside-the-car/
climate control is stuck on heat, common issue.
to test see if ur aircon works properly.. or atleast try get it to blow cold air thru it then see if it gets hot.
well now that you mention it the AC isnt working....i never knew it was linked.
would it still be stuck on heat even if the AC control is off? or using different settings?
if it is indeed stuck on heat...how does one fix this? i suspect it has something to do with the Wiring into the ECU? (im using a PFC)
Edited by Jap_Muscle
Given you just had work done done on the car I'd say the ambient sensor is unpluged ( it should be the little black lump next to the horns, behind front bumper).
Like GTScotT said its a common thing, mechanic forgets sensor, A/C thinks the outside temp is -40C or something and fires up the heater 4 ya
There are 2 other sensors, one at the back of the dash ,left side (sunLoad) and one just to the left of the steering columb (interior temp).
Any of these left unpluged/faulty will screw up ya AirCon (usually with the heat your gettn)
Cheers
EDIT: Water temp hitting 110C sounds like a seperate issue, I THINK this is a common issue 4 workd motors (I'd sujest you search SAU 4 this one, I've seen a few good posts covering this)
Edited by BundyBear
had this happen to me once. felt hot air coming through vents etc.
watched the oil and water temps but nothing unusual. i thought something was f**ked.
Turned out i'd bumped the air con control and set it to 30 something degrees so hot air was coming through the vents even though the air con control was off :S was quite weird
Im not sure about the 34 but i know with the 33 that if the climate control is on 18, 30 what ever, it will lightly blow that temp even if it's turned off.
Can confirm that for my R34 is the same - I was surprised when I noticed :P
it does indeed do this, but ive always had it set to 18c on the board....turned on or off it blows hot air.
ill check all the sensors...hopefully they all working
definitely stuck on heat then mate, even with the ambient sensor unpluged you should be able to turn it back down each time you drive.
ull have to go thru the whole system and check everything, heater tap, plugs etc
hit the recirculate button (inside air ) to stop the blowing with the aircons off, the cowl vent door gets left open
its been said B4 but, the designer of the A/C should be shot
cheers
EDIT: Some 'Console' programs can diagnose the aircon, might be worth a shot if ya got access to one
Edited by BundyBear
Remember that it's an electronic computer and not a manual switch, quite easy for something to fail electronically and the signal not make it to the solenoid. I agree with everyone else, heater stuck on...
hey mate ,do you run themo fans on your set up ??as i have a twin turbo rb 30 /25 set up running 488 rwkw and i was running themo fans and driven around wasnt to bad but i soon as i got a red light or went through a drive through temps would clim ..up ..i pulled the themos off and put the standed fan back on ,and didnt have any more troubles with the temp climming.
cheers
there is a sensor that is prone to breaking, its near the windscreen on the inside above the glove box.
when it goes you basically have 2 settings.... 18 (cold) and everything else (hot)
you need to turn it to 18 and then turn it off to get it to stop blowing hot air :ph34r:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
