Is it ever better to go just past the limit of adhesion and get a little tail out, assuming it can be done smoothly? If so, when? Or will this be slower since static friction is higher than kinetic friction? (32 GTR, pretty sure the rear LSD is good)
https://www.sau.com.au/forums/topic/304520-circuit-cornering-theory/
  • Replies 48
Really, its such an impossible question to answer.
But put simply if the car is moving sideways then it isn’t moving forwards. If your steering angle is sharper then it needs to be then your lateral load is higher then it needs be which means tyres are being asked to do more work then need be….but that’s in the classroom. In a light NA car then it would kill you. In big heavy cars that flop all over the track and have the sort of power only racing cars had in past decades then a bit of crossed up action doesn’t cost you near as much.
If you're trail braking into a corner you can apply an amount of braking that would otherwise have you understeering, but is counteracted by the tail stepping out. It would theoretically let you brake deeper and carry a higher entry speed. Especially with an AWD car, you could rely on the front wheels to pull the car out of the bend if the weight shift didn't regain rear traction when you came off the brakes.
Being able to pull a move like that off consistently and accurately is another question. And, at any rate, using trail braking to slide the car around every corner would only ever be useful in a situation where tyre life wasn't important.
Also, if you saw Jenson Button's second visit to Top Gear they showed footage of the race where he clinched the season. He made a move where he dived up the inside of another car going into an S-bend, and kicked the tail out before the direction change.
He said he did it to make his car wider on the track and intimidate the other driver, stopping the guy from re-passing him and allowing Button to get to the next curve first.
Theoretically, as a tactic to maintain position (rather than improve time) it was better than not doing it.
I say yes. we're talking about a road car, or at least very much a production based car, with little to no areo, semi slicks, so limited mechanical grip, going for a single fastest lap time. Not about endurance racing, or even keeping tyres together for a 30 lap stint. And we're not talking about cars with lots of mechanical grip and areo.
I say smoothly loose is the fastest way. You need to be right out at the very edge of the envelope if you are going to get every last bit of time out of the car. Staying perfectly straight means you are staying inside of the car's limits. There's more to be had.
Look at videos of production based touring car racing, like Group A or Group C. Or look at the front runners in IPRA (they run semis). Look at how the top handful of drivers in Superlap do it.
Which part of the corner are you talking about?
Generally you can divide it into four.
1. Braking
2. Turn in
3. Mid corner/apex
4. Corner exit.
Clearly you cannot stay on the limit of adhesion during all four parts.
But it is a common technique in a GTR to trail brake to during turn in. I usually do. The down side is that it can put you at a difficult spot in the mid corner as the car will want to understeer as you get off the brakes.
As for corner exit it is simply a matter of getting the car sufficiently neutral (ie trying to banish the understeer past the apex)so you can get on the powah & also programming the AWD system to keep the car balanced ( ie remove/reduce wheelspin & oversteer)
If you watch the formula fords or other low(ish) powered cars with little aero the fast guys are the ones who look a little loose in the midcorner. This allows them to get the power down earlier on corner exit.
Edited by djr81
im with him... get on the edge and push the boundaries... even if its slower, it will feel faster and make you happier, theatrics are better than lap times. i like to trail brake to make the back end loose and swing it out a little before the apex, then get on it after the apex, not full drift, but not fully straight. this keeps the rpm up and the car doesnt bog down as much when full grip comes back to the rear wheels. thats with a lowly rb20 though.
I would say depends on the car you are driving as it seems with the evo's the rougher you drive them and make them slide around the faster you go.
With a FR car if you get the tail out then it limits the power you can get down and the exit speed is affected so i would say no.
FF rear out would be OK as aids in turn in with the nose of car moved around to point out of the corner sooner to allow you to get the power on earlier.
Matt
i find that i turn left the hit the gas
and for right handers i turn right then hit the gas
i red this in a book!
so the only logical conclusion is im farken shit hot and ful sik!
repeat above
this man..... he knows.
You mean like this:
http://www.youtube.com/watch?v=OOP3_1TsXs4
This car has also won the UK time attack pro class season for the second year running.
Drving grass lines and ham it up with oober power gets you interwebs stylez points....
don't get me wrong it's looks to be damn fast, but being a bit tidier would probably be quicker. Tank slappers out of a corner is not fast.
Check out the same car midway through this video. It shows you why it has won the UK time attack pro class season for the second year running.
Edited by SABBAi
Agree with the above.
I'm a firm believer that smooth driving is the best way to yield time on a track. That being said as I got faster at a place like PI, the car steps into an 'oversteery' stance around a few corners as I feathered the throttle and re-applied. I also think that the fact I now trail brake into two of the corners allowed me to get under the 1:50 mark. Not only are you saving time in the braking zone but as I get off of the brakes the car steps out a little before getting back onto the gas which helps tighten the line and maintain speed.
I've seen that vid before from 3.15 onwards...much tidier....but then again Silverstone is a beautiful track...long wide sweeping corners.......if only we had those types of tracks in Oz .
Yes I'm sure the video link I posted of that car was a bit of a "promotional video" and clearly was not some of Olly Clarks best work.
Edited by juggernaut1
That's my thoughts on the subject also.
Having said that, there're obviously much more to it than loose or tight.
You can be loose or tight at differing speeds on the same corner given your angle of entry, exit, throttle pickup point, steering wheel inputs, throttle inputs, degree of braking skill etc. Not to mention what's coming up after the corner or how you navigated the previous section of track, your position in a race (if racing), if you're going for a fastest lap time or going the distance in an enduro.
That's the beauty of corners and racing in general, a million ways to do it wrong and right :P
At the very least finish the race/lap and that will put you ahead of some people :(
the best way is the one that gives you the lowest number on the lap timer. I don't know what it is yet but when I find it I'll let you all know too. actually fk that. I'm keeping it to myself....
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
