  On 24/08/2011 at 8:09 AM, XRATED said:
Sounds promising.... :thumbsup:
Are you going to run one of they're pumps still?
Nah. I already bought a Reimax pump which I have atm. It has a slightly higher flow capability then the nitto and I think I will need as much as I can get as im running loose clearances and feeding both the turbo and charger from the engines oil supply.
Hopefully tomorrow when I get some time I will be able to write some kind of spiel on the engine build. Be warned I have limited photos as Its a little difficult to take some of myself doing stuff!
The engine is assembled, im just bolting on manifolds and getting everything sorted before it goes back into the car. Dummy fitting things to make sure they still line up and will work then getting ready for final assembly. It really takes alot more time then you think. Then you lose stuff or misplace special cut down bolts and studs and got to remake them. Its quite aggravating when things progress so slowly.
Thats pretty well it as it sits now, except I have the exhaust manifold bolted on and the supercharger mounted. Will get more pictures tonight when I hopefully get the turbo assembled and bolted up!
Just the two vents and one drain bung. Exhaust side has two extra oil returns. I have oil return from charger, oil return from turbo, oil return from side of head between 3 & 4 and oil return from std front.
I am hoping to go, but only if I get the car finished in time and sorted. If not then I wont bother going.
Turbo is assembled and bolted on loosely. Everything appears good so far. Need to get oil and water lines sorted now!
it's going to look absolutely SICK all plumbed up. seeing it now it should work nicely with the charger sucking through the turbo at lower RPM then the turbo blowing through the charger at higher RPM. I'm guessing this way with a shared path you don't need to have tricky 1-way valves/solenoids etc to swap intake paths between turbo and charger.
I hope it kicks arse.
Mate, you are not wrong! Ive spent more time just looking at it some nights then actually working on it lol. Yeh, having it plumbed in this configuration is alot simpler. It would be a nightmare doing it any differently as space is a huge issue!
Alright! Got all the lines finished off and inlet manifold on and the rest of the junk bolted on. It took a few hours of fiddling last night, but she is in!
Thank god for that!
Hey Mike,
good to see you're still working on it.
Quick question (forgive me if I have asked it before)
Have you slowed the blower drive down after fitting the turbo? I think from memory you were running around 1 Bar with the the bypass valve full open?
My thinking is that by slowing the blower down you could run the turbo closer to its peak efficiancy without having to run 50psi to do so (if that makes sense)
Also because I'm curious (and the fact that I wont have to try and get my hand down there lol) will you run a boost gauge beteen the blower and the turbo, would be intesting to see if there is any pressure drop or even gain post supercharger.
  On 18/09/2011 at 11:56 PM, zebra said:
Hey Mike,
Andrew,
Yeh im still working on it...slowly.
That is correct mate, I am slowing the blower down, well trying too anyway. Im attempting to get somewhere between 7-10psi out of the blower, but space is going to prevent that via pulley sizes unfortunately. I can only go so small on the balancer due to the bolt pcd and supercharger can only go so big because of the idler pulley placement. I dont know what the maximum boost could have been before as the belt was slipping to the shit house. It peaked at 19psi with that setup. But the sprintex calculator pulled a figure of about 30psi, but I doubt that it is accurate, even though they have said they can run that much boost.
My own thinking is tracking exactly with your own on this. I would like to run low psi out of the charger and just play with the turbo psi inorder to achieve more flow as the turbo flows atleast 50% more then the charger, otherwise I would be running 50psi by trying to utilise the turbos higher flow capabilitiy. Is that what you are thinking too or something along those lines?
My base calculations at the moment are telling me that 10psi out of the charger and 10psi out of the turbo will net me about 28psi post charger, due to the compounding ability of the setup. Though I would rather less then 10psi out of the charger and make up the rest with the turbo.
Yeh I am planning on hooking up a boost gauge between the turbo outlet and charger inlet to see what will be going on down there :)
You should move to Brisbane mate then you could come see for yourself....and maybe help :P lol.
  On 19/09/2011 at 2:45 AM, r33_racer said:
Andrew,
you hit the nail on the proverbial with what I was thinking.
and LOL there are plans to move back up that way next year sometime.
  On 19/09/2011 at 2:57 AM, TiTAN said:
should be interesting to see how early it hits 200 wasps.
Yeh it will be interesting. No idea when though, but im more curious about what the peak power will be and whether the charger will be a restriction or not. Just going to have to wait and see.
Cool. Well it seems like the logical way to go to try and maximise power while trying to keep the boost to a slightly sensible level. Otherwise I will have to run the car on straight methanol to take advantage of the super high boost and not have detonation issues! lol.
You should move here now....its starting to warm up quite rapidly. QLD likes to skip spring and go straight to summer!
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
