  • Replies 44
oil analysis? there was a thread in the last week where someone (elite I think) posted phone numbers for capital cities. if you don't want to pull the motor analysis is 100% the way to go....couple of days and you will know.
too drunk to find it myself its a bacheloring weekend for me
if its a spun big end bearing the noise gets louder as the rev's go up, the more load/rpm, the more cylinder pressure the bigger the bang.
sounds like a hammer on the crank as said before. the noise will NOT go away as rev's go up. and it WILL get worse with each time a load is put on it.
The noise of a spun big end bearing is actually a gap between the crank and bearing allowing the big end bearing to bang down each time
that cylinder fires and then slams the big end down on the crank.
  • 1 year later...
yeah I don't know why people are so afraid to spend $40 on UOA? i've been doing it for nearly 10 years on my GTRs and it tells you everything you need to know. especially if you start when the engine is still good, that way you have a solid baseline and if something starts to go wrong you know straight away. it also helps you set accurate oil change intervals etc.
For me the 'cut spark' method has never failed.
Am not sure why more people don't have the same faith.. I think it was particularly clever of the OP and thought it showed he had a decent understanding of what he was doing.
Meh.
so what would be causing a spun end bearing???
How do you avoid having one?
A done bearing is normally caused by an oil related or stress related issue. Oil related would mean it was starved of oil or was poorly serviced.Stress related is not as simple as it sounds.. It does not mean ringing the neck out of the motor, it more so means stress directly on the bearing itself. That could be caused by ping/detonation, piston contact with valves (rarer case but something not to be missed if you do have a piston meet a valve) or abuse. By abuse, I particular mean starting the motor and giving it too much stick before its at operating temperature.
A brief summary of my experiences... I have never owned a motor that blew anything more than a head gasket. I have never owned a motor for less than 40,000km and I have never owned a motor that did not see its redline daily nor for less time than it sat idle at the lights. I NEVER give my car any sort of 'stick' within the first 5 to 10 minutes of driving. My last 2 cars were thrashed the most, both of them are still running with the new owners and both have high KMs on the factory bottom ends.
Every friend or acquaintance I know who has thrashed their car from start up, has had it bite them in the bum sooner or later. We are currently repairing my own brothers 911 motor at a cost of over 20 grand due to his sheer lack of care for my advice.
Turn the key and drive it unreasonably before its truly at a reasonable operating temp and you WILL run into problems sooner or later. My brother thought he could get away with it because he always owned newer cars, now either hes owned this car long enough, the previous owner also did the same thing, or hes just simply got the kind of motor that couldn't take that kind of abuse for that long, but I'm sure he will remember the debt.
Is it possible to repair the big end bearings without removing the head? for eg, engine out..put on stand..flip the motor upside down to work on it???
Provided that the only damage done is to the bearing itself, then yes. It really depends how much damage has been done.. Sometimes you will have a bearing look like its lost its first layer or two when it makes the noise, others will start to knock and utterly destroy themselves soon after. What that means is, the bearing does not evaporate to the magical land or none.. It will grind away into metalic dust and contaminate your oil.. Your oil, being the life blood of the engine, will carry the said contaminants throughout the motor and will possibly damage other aspects of it in the long run.
Is glittery oil normal after a fresh engine rebuild. I just rebuilt my motor and im hearing a noise as weel from cylinders 5 and 6. Sounds like more of a top end noise with the stethescope but im curious about the glittery oil during the break in period. Looks like a goldish color.....
Sorry but that is almost certainly not OK. If someone else built the engine, talk to them before you start it again.
If you built it...I guess you can start with oil analysis but 99% you are going to have to pull it out.
How is the oil pressure?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
