lol ill still beat u :)
someone organise a east meet for the 15th or 16th :)
eh, so be it. when im off my P's and buy an R32 GTR we shall see! :P
tho that thing would be so f**kin old!
so are the l28's any good?
there's not much performance gain from L24 to L28, unless you really work the engine. I mean ideally if you wanna keep the old school donk you'd wanna bore it out to a 3.1L and fit some mikuni carbs to it or someshit.
but here's reality... you nor anyone on this side of the planet will not be fucked doing all that. so just keep the shitty engine that's in it till it carks it from a cracked headgasket or soemthing and then throw it out, find another engine and repeat the process till you can afford a better car.
here are your order of priorities:
1. get car in registerable condition
2. register car
3. make sure it drives OK
4. modify it or think of changing engines
now stop being a retarded dickbag with grand dreams when all you've got atm is a shitty rusted out car that's not even on the road.
Thats the time frame I'm there lol. Hopefully it's the last interstate work I have to do for a while.
Been to Perth, Launceston, Brisbane and Mackay in the past 5 months. Add another Brisbane to the list as of next week.
my flight was to mackay and then a 5 hour trip up north just off cairns. The humidity was a killer up there. More water than oxygen. 24/7 Aircon in the car and at the house lol
Funny to see people having water hoses running 24/7 watering a patch of dirt. No water restrictions up there.
A damn!
That's awesome!
LOL! Kris loves China Bar.
I would have came but I only got on SAU while you were all heading out, + I needed sleep after NYE.
Kris doesnt love China Bar as much as I do. I wasn't going out for Rock Kung at that hour...pfft.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
