Wasn't quick enough with my camera though. Was just chilling watching the Simpsons, and just heard a massive roar, so I ran outside.
Funny the amount of people on their balconies in their underwear lol
http://www.heraldsun.com.au/news/victoria/...x-1225823494137
Saw the aftermath of this last night, near Lygon St. Almost looked like the cop car had rammed the car it was chasing, but obviously after reading this, it's a little different.
buy my 32 then cause itll be under the power to weight rule when i take mods off
and looks hawtttt, you know u wana
.... gota love sedans re :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
