whats the most OT anyones done in a pay cycle (monthly)....
one of the guys in my team last pay cycle did 102 hours OT... thats double time OT... so 204 hours standard pay... thats f*kin nuts! think the most i ever bothered to do was about 40 a month. He must have got a fortune last month. He paid over 3k in tax :D
around the 200 mark.. but chef's dont get OT
$95 a tyre?? J got my federals for more than that... 595ss 245's on rear. Grips alright for the price
Ah LOL!
It's for a 14" MA61 wheels.
Tyre size 185 / 60 / 14R
For my Rolla, just need a good set of tyres for daily use.
get retreads? lol
Hell no!
Had a retread on my dads car and on of the retread separated and we could hear this unusual noise and thought the suspension was playing up.
It was the separation that was causing the noise.
So we changed the retread to a brand new tyre.
LOL!
I'm due for a new set of 14"s... to Melbourne Cheapest Tyres!!
Are they the ones who specialise in 2nd hand tyres and then sell them?
3k isnt enough on a 11k pay per month i get taxed more then that on slightly more p/m.
having said that your friend will get it all/most back most likely as he wont actually earn the equivalent of 11k permonth across the year.
$20 an hour? thats f**kn slave labour..
I ignored a HECS/HELP debt
http://ato.gov.au/scripts/taxcalc/calc_standard_hire.asp Try it out
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
