Sweet thanks, now to see if I can get a refund and transfer my domain
Or you can try these guys out. Really cheap hosting
http://www.justhost.com/web-hosting
Look on the internet for coupon codes, theres plenty available.
edit: when you close the website, a popup comes up giving you 20% off. Although there are better coupon codes floating around.
where can i take my car to get a RWC that knows skyline? need to get it done by the 27th. got a freakin major defect for having HID's. couldnt find anything else :thumbsup:
car is in good shape and i know it has nothnig else wrong with it.
sigh called few places if used before and all i busy the whole week witht he earliest booking next wendesday. only ppl free are ultra tune but i really dont want them to do the RW as we all know they are a bunch of morons
quite switched on??? lol i dont think so
they serviced my R33 told them to check everything. They called me and asked if the car has 4 wheel steering and im like ye HICAS. his like well its not working. your rear wheels don’t turn when you turn your front wheels...told em it only comes on while driving you freaking noob and he proceeded to argue with me. when picking the car up his like ye i read about it and you were right.
they also pulled out a list of things to be changed but none of them needed to be changed. it was parts they thought are on the way out but needed replacing and 90% of them were vacuum hoses which i replaced with brand new oem parts the week before servicing.
never going to ultra tune ever as they try and squeeze money out of you by telling you things need replacing when they dont. so to me not quite switched on. but everyones experiance is differance but im never going there again.
oh it was the knox shop as i live close to knox :thumbsup:
Depends which guy you get. I know they have switched owners lately so that could be why. When Bobby owned the shop it was great. I think Patty still works there though... He did a good job on my car.
Dandenong Ultratune though = epic fail. They broke my f*cking key. Snapped it in the door...
Now I only go to Marquis Automotive. Don't know if he does RWCs though. If he did then I would definitely be recommending him.
Ultratune at Knox are actually quite good. The mechanics there are quite switched on. Tell them you know the guys with the black and blue MR2s :thumbsup: They'll look after you.
ultratune at knox can suck on my sweaty testicles. you can tell em that was from shan with the widebody r33 sporting a carbonfibre front bumper spoiler which they broke into 3 pieces due to negligence. Ask em how switched on they were when they were asking me if it did good skids 2 seconds after we told em "we're trying to find someone who sells pirelli P-Zero's in a 355 width".
Ballbag loving knobjuggers, fuck ultratune at knox.
All this cos I just asked them to check out the suspension before a track day. shit kents wouldn't know a spanner from a hammer.
GSB Glen Waverley?
That has to be quoted!
I could not stop laughing at that.
:thumbsup:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
