Sweet thanks, now to see if I can get a refund and transfer my domain
Or you can try these guys out. Really cheap hosting
http://www.justhost.com/web-hosting
Look on the internet for coupon codes, theres plenty available.
edit: when you close the website, a popup comes up giving you 20% off. Although there are better coupon codes floating around.
where can i take my car to get a RWC that knows skyline? need to get it done by the 27th. got a freakin major defect for having HID's. couldnt find anything else :thumbsup:
car is in good shape and i know it has nothnig else wrong with it.
sigh called few places if used before and all i busy the whole week witht he earliest booking next wendesday. only ppl free are ultra tune but i really dont want them to do the RW as we all know they are a bunch of morons
quite switched on??? lol i dont think so
they serviced my R33 told them to check everything. They called me and asked if the car has 4 wheel steering and im like ye HICAS. his like well its not working. your rear wheels don’t turn when you turn your front wheels...told em it only comes on while driving you freaking noob and he proceeded to argue with me. when picking the car up his like ye i read about it and you were right.
they also pulled out a list of things to be changed but none of them needed to be changed. it was parts they thought are on the way out but needed replacing and 90% of them were vacuum hoses which i replaced with brand new oem parts the week before servicing.
never going to ultra tune ever as they try and squeeze money out of you by telling you things need replacing when they dont. so to me not quite switched on. but everyones experiance is differance but im never going there again.
oh it was the knox shop as i live close to knox :thumbsup:
Depends which guy you get. I know they have switched owners lately so that could be why. When Bobby owned the shop it was great. I think Patty still works there though... He did a good job on my car.
Dandenong Ultratune though = epic fail. They broke my f*cking key. Snapped it in the door...
Now I only go to Marquis Automotive. Don't know if he does RWCs though. If he did then I would definitely be recommending him.
Ultratune at Knox are actually quite good. The mechanics there are quite switched on. Tell them you know the guys with the black and blue MR2s :thumbsup: They'll look after you.
ultratune at knox can suck on my sweaty testicles. you can tell em that was from shan with the widebody r33 sporting a carbonfibre front bumper spoiler which they broke into 3 pieces due to negligence. Ask em how switched on they were when they were asking me if it did good skids 2 seconds after we told em "we're trying to find someone who sells pirelli P-Zero's in a 355 width".
Ballbag loving knobjuggers, fuck ultratune at knox.
All this cos I just asked them to check out the suspension before a track day. shit kents wouldn't know a spanner from a hammer.
GSB Glen Waverley?
That has to be quoted!
I could not stop laughing at that.
:thumbsup:
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
