On the topic of Real Estate agents...
The muppets who manage the property I am renting, recently did an inspection, and claimed the carpet is dirty...when in actual fact it was like that when I moved in (brand new place), yet it's now MY responsibility to clean it. Got photo's and the initial inspection I filled out to prove them wrong, but the tenancy union are a bunch of weak f**ks.
if your talking about your vacating inspection it is mandatory for the tenant to steam clean the carepts upon exit it will be clearly stated in your lease, if your still in the property and not moving out you can tell them to get fkd but keep in mind when you go to leave you will have to do it VCAT wont help you with it and yes the tenants union are useless if you got questions feeel free to pm me or something i did property management in my early days :blush:
Well I'm going to move out anyway, but yeah, aware that we need to steam clean it before we leave. Just a pain in the arse that the place was dirty when I initially moved in, and the fact that I had to wait a couple of months for the correct remote for my split system in the living room. Very unprofessional on their part me thinks.
yehh i hear ya man common problem unfortunately all that you mentioned is up to the landlord and they are the biggest tightarses/lazy mofo's around i found they are harder to deal with then tenants usually but the tenants are the ones who always cop the shite :(
f**kin bummed i missed goodlife.. i thought it was on the 31st -_-
started playing MW2 online on ps3.
damn there are some pretty good people on there. like respawn and bang your dead
add(own) me peeps. sam3075
hmmmmm... ive lost 6 hours of memory.
i remember our cricket team thrashing the shite out of our opponents at the grand final... then i remember going back to the club rooms and having about 4 beers, then shotgunning a beam and cola then waking up on our couch nekkid at 8am this morning....
i also dont seem to have my phone any more... or my oakleys... lol
i do have my sim card though which has me intrigued as to the phones fate
dropped in the loo/river for sure. check under your nails to figure out which.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
