might bitch out and run 225's on it. I'm running 215's on 9.5" rears on the ceffy, and it handles just fine. With the golf though, I want a near 60 degree sidewall to tuck in under flared out guard lip. Golfs run a factory fender flare, then a lip. Most guys homo out and just leave it as it is and try and tuck shit under it. I wanna make that lip follow the angle of the fender, then make the tyre run parallel to it.
Anyways, got the wheels. Should cost about $1300 landed. I hope. Been ages (almost a year) since I bought a set of wheels, god knows what the price of shipping is these days... and I cbf waiting for a container.
who would've thunk a Subaru Legacy is perfect fitment for a VW Golf...
looks like a spitz of some kind
lol i've got wheels and I don't even know what colour the car is... apparently I've got a choice of two, one is blue and the other is silver. choices... lol I'll probably pick the one that is cleaner.
liking the idea of blue with silver chrome wheels though... probably end up respraying it black with some ghey off centre euro racing stripe.
this is the look i''m after... minus the overdone flat black... and the wierd bits on the front bumper... maybe a smidgen higher so i can kiss the fender with the rim instead of tucking the lot like a dirty minitrucker.
gonna be baller.....
soooooooooooo i've sorted out how to fit the wheels to my ke70.... and keep it slammed (15x8-9)
flare guards 2"
castor wheels forward 1"
xt130 lca's to camber it in around 1.5"
hacksaw the fronts of the guards around 3" forward
195's
the rears need a big flare + some stretch and that's that
also i'm puttting an s series rear end on there which will act like 2 x 10mm spacers
FFFUUU suspension for both the R32 and the Golf is gonna cost me a month's pay. FML.
funky fk that vw looks like shit fitment.
Yeah he's running a 5x100 PCD to 5x114.3 PCD adapter, and even then he's settled for the minitrucker look. The Meister's I got are 5x100 PCD and have maximum allowable offset. If my calculations are right it should poke out an inch so that I can flare the guard to cover it.
Oh - what hours you working this weekend/long w/e funkeh - i comes get PC bits :down:
dunno if I cbf working this weekend... I'll chuck the mobo in the boot of the car, so just tell me when you're free and I'll come see you.
yeh should look the goods what colour is the car?
fucked if I know, I haven't even seen the car yet. All I know is that its an MK4, and its petrol, and that its gonna cost $5000. My mate's handling the buying/sourcing. Needs a VIV, but we do that day in day out, no probs.
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
