Tell Blipman that :)
I do, on a regular basis. That's why he went and bought an R33 ;) Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
I've never met him. Just occasionally interact via the aus300 forums.
I agree on the Z31 for sure. I can't see anything attractive in that car. Does absolutely nothing for me.
Blipman's Z32 was pretty nice I reckon.
What's wrong with a VH45?
LSx's are lighter, cheaper and more reliable.
oh... lol yeah I used to sit about 2m away from him every day at work for a year n a bit. reminded him almost every chance I got.
I've got a nice 300ZX right here for you :P Haha.
:P
Even if it was twin turbo, I would not take it.
congrats, you own the 3rd ugliest Fairlady of all time.
:cool:
I do, on a regular basis. That's why he went and bought an R33 :P Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
LOL!
Only reason I would take a 280ZX is cause at the time, it was hard to a 240Z / 260Z.
I would still prefer a 280Z over the Z31 and Z32.
At least it retained some of the classic shape / styling lines.
240Z / 260Z = all time best Fairladies!
Not much of a fan of the newbie 350Z and 370Z's either.
given a supra, 300zx and a mr2, I'd probably take the mr2 over the lot. fuck driving land barges off. at least an MR2 turbo is zip zip fun times.
i automatically assume anyone driving a 300zx is in their late 30's and working some entry level job (can't afford anything better).
poopra drivers are hard to predict, they're either tossers like 3 series BMW drivers or they're guys who love drag racing but got snotty with the fact that power windows don't come factory on commodores.
:P
Your opinions amuse me and the fact that you are usually spot on.
:cool:
I think you should sell it and the Supra and buy a GTR.
Yeah. Will be R32 GTR or a modded MR2.
There seems to be alot of MR2s popping up for sale now with forged rebuilds and everything done. They're going for relatively cheap too. Much much cheaper than a GTR.
So when the time comes I will look at the wallet and make my choice then. Either way I'll be happy.
I've never driven a GTR but I did drive Chad's GTS-T and loved the feel of that. Have driven an R33 and it really did nothing for me.
I think I just prefer slightly older cars.
Edited by jezza boii
Sounds like a plan!
a GTR is nothing like a GTSt. nothing. they just have the same headlights.
True that!
wait till you drive one.
Hell I even got to drive a 200ZR with an RB26DETT and I was like "sweeeeeeeet", started the car and took a corner and went "FFFFFFFFFUUUUU".
first day at cadbury = great success
First task was taste testing cherry ripes :cool:
Picked up 5kg of Picnic for $8, will get a box of boost tomorrow :P
haha you're so getting diabetes.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
